Tools and cold temps
Oil Fed Air compressors: If they are cold, get them warmed up before attempting to use them. Cold weather will thicken the oil. Turn it on, and you can burn out the motor.
We prefer to use our oil-less smaller compressors or paslodes in the winter.
Paslodes all require warm gas cylinders. We keep them (a few cylinders) in the front of the truck, so that they are warm by the time we get to the job site.
If you have tools that get wet, do not put them in storage, or they will get rusty. Same thing, if you bring them from cold to warm areas, they will condensate moisture. If put away, they will get surface rust.
Don't be afraid to use WD-40 and silicone spray on some of your tools, as they disperse H20.
I'm sure that there are other pointers. Other than that, there are no worries about leaving tools in cold storage. We have tools that sit in the back of various trucks, vans, enclosed storage trailers, unheated storage garages...all winter long... = zero issues (aside from what I posted)
- Build Well -
