Which Tool To Detect A Hot Wire? - Tools - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 09:05 PM   #1
Rewards Points: 682
Which tool to detect a hot wire?
My electrician used this pointy tool to identify which wires were hot. He just pointed the tip close to the insulation of the wire in question.
What is the name of that tool? It looks very useful.
darsunt is offline   Reply With Quote
Old 03-05-2012, 09:09 PM   #2
Code05's Avatar
Rewards Points: 1,104
Non contact voltage detector or volt tic or voltage pen tester.
Here is one brand.
http://www.fluke.com/fluke/usen/elec...048&trck=1acii
Code05 is offline   Reply With Quote
Old 03-05-2012, 09:11 PM   #3
Rewards Points: 14,306
It's called a non contact tester. Lowes, Home Depot, any hardware store has them.
Old 03-05-2012, 09:59 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Here is a cheapie; http://www.harborfreight.com/non-con...ter-97218.html
Then there is a primo model that has an adjustable voltage threshold that works great in crowded boxes and works down to 12V lawn lights
. http://www.amazon.com/Greenlee-GT-16...ion/B001QIJOW0.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-05-2012, 10:46 PM   #5
Tool Geek
PaliBob's Avatar
Here is a pic:
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-05-2012, 10:59 PM   #6
Registered User
Rewards Points: 526
The adjustable one is better. As Bob said, in a box it tells which exact wire is hot, and for siding a remodel it is sweet. Turn up the sensitivity to find the live wire path and mark it on the WRB so you don't put a fastener in a wire placed too close to the exterior side of the stud. Traces the wire path above the drywall ceiling when they are on top the ceiling joists. Floor joists also, very handy.
Gary
Old 03-05-2012, 11:17 PM   #7
Rewards Points: 682
Thanks I think I will get one right away.
How does it detect the hot wire when the electrons aren't moving? Is there a magnetic field there even when there is no current flow?
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 12:51 PM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 01:23 PM
how to detect an open wire end in the ceiling? tmai Electrical 3 11-17-2009 11:27 AM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
