-   Tools (http://www.diychatroom.com/f29/)
-   -   Toe-nailing with pneumatic nailer problem (http://www.diychatroom.com/f29/toe-nailing-pneumatic-nailer-problem-73362/)
nthom1111 06-10-2010 04:54 PM
I rented a pneumatic framing nailer and air compressor with 3" nails to install an interior non-loadbearing wall. I could never get a single nail to shoot from an angle (toe-nail) to go all the way into the wood. They are all sticking out at least a quarter inch. I have to go back with a hammer and try to either hammer them in or pull them out. Shooting straight into the wood was not a problem - nice tight fit.
The safety tip on the nailer tended to slip - nothing grabs onto the wood. I had the air compressor set to 115 PSI. There is a screw adjustment on the safety tip. I tried adjusting that in or out but it didn't seem to help. Any ideas?
I am done for the day but will need to rent it again for another wall and would like to be ready.
Thurman 06-10-2010 05:35 PM
Not sure I have the answer for you, but if I were to rent a framing nail gun again, from the same people I would have to tell them about this situation. I have a framing nailer that I use often, and will use the next two weeks, and it will drive a 16d to the head toenail style. David
fabrk8r 06-10-2010 05:56 PM
My framing nailer, a senco, does the same thing in tight quarters.
I use a palm nailer to drive the nails flush after nailing all the toenails with the framing nailer.
It's an extra step, and takes a little more time, but it looks good when I'm done and it's faster and easier than setting them by hand with my framing hammer.
kwikfishron 06-10-2010 06:12 PM
199 Attachment(s)
Love my Palm Nailer, couldn’t live without it.
The most inexpensive, easy to repair nailing machine ever made.
jlhaslip 06-11-2010 02:43 AM
Hammers are old fashioned, but they work fine.
Cool Breeze 06-11-2010 10:50 AM
Hi there... what brand of nailer is it? Most come with a removable plastic saftey cap that conceals agressive toenailing teeth. I have the Bostitch F28WW, and the plastic cap pops right on and off. I can't imagine a framing nailer being constructed without those "teeth" used to grip the stock for toenailing.
Thurman 06-11-2010 04:16 PM
Not sure who you are asking about this. BUT, if me: Mine is one of those package units which had three (3) guns in the package at the blue home improvement store. I do not build homes, just do HandyMan work and use it occasionally. Yes, it had a plastic tip on the end (pacifier, I called it) and I threw it away real soon. Errr, I think it had an adjustment to set the nail depth and I may have (probably did) fool with it. David
Cool Breeze 06-12-2010 11:16 AM
I was asking the OP... it sounded from the description of the problem "The safety tip on the nailer tended to slip - nothing grabs onto the wood.", that maybe he just never removed that pacifier part. Great name for it BTW, totally using that from now on.
eisert 06-25-2010 09:28 PM
I use nailers every day. If you are toe-nailing with a nailer and using an appropriate angle for the nail to do its job, most nailers wont drive the nail flush when actuated. The driver in a pneumatic nailer is only so long. When you tilt the nailer to toe-nail, you are extending the required length of travel required by the driver to flush the head of the nail.
