Are these good respirators and safety masks?
I use these 'aeero tech' safety products from home depo:
ao safety respirator with 8053 p100 cartridge, NIOSH 12777b ao safety N95 respirator (dust mask). The cartridge respirator I use for pesticides, solvents and severe dust. The dusk mask I use when sweeping, sanding, etc. Are these good safety tools? Or are there better ones? Thanks |
If it has a NIOSH N95 rating, then it was tested for Negative pressure 95% efficiency. The P100 cartridges will filter 99.97% of particulates. P100 cartidges do nothing for organics like pesticides. You need an organic cartridge for vapors. Some cartridges can be stacked so you have both. Some companies offer organic and P100 capability in one cartridge.
p100. The cheapest way is to just use the cartridge you need. I normally use a P100 with a prefilter snapped over it to prolong it's life. Prefilters are pennies compared to the main cartridges. |
| All times are GMT -4. The time now is 08:18 AM. |
