Which Of These Drills Is The Best? - Tools - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 06:47 PM   #1
Which of these drills is the best?
Hi folks, as mentioned previously I am looking to buy a drill that will work well in masonary, Screwfix have some really good ones but not sure which one would be best- I was thinking of this one
DeWalt DC100KA-GB 18V 1.3Ah Ni-Cd Cordless Combi Drill http://www.screwfix.com/p/dewalt-dc1...bi-drill/73596
the price is really good but I am not sure whether I need something with more power
ie these ones-
DeWalt XRP DC988L1 18V 2.0Ah Li-ion Cordless Combi Drill http://www.screwfix.com/p/dewalt-xrp...bi-drill/74113
Makita BHP451RF 18V 3.0Ah Li-Ion Cordless Combi Drill http://www.screwfix.com/p/makita-bhp...bi-drill/48855
I am not going to be drilling into concrete, just bricks so if you guys think the first one would be suitable for that then please let me know. Thanks
Homervanderjazz is offline   Reply With Quote
Old 02-21-2012, 07:45 PM   #2
Learning Things Every Day
Jay 78's Avatar
Under Construction
Jay 78 is offline   Reply With Quote
Old 02-22-2012, 04:29 AM   #3
re
Thanks for the reply, they are actually all hammer drills- in the UK cordless hammer drills are called cordless combi drills, the one with most torque seems to be the makita but it is also the most expensive, how important is the torque difference between these drills? Also why are you saying you would not buy any of these? Thanks
Old 02-22-2012, 12:01 PM   #4
47_47's Avatar
Rewards Points: 62
Wouldn't waste my money on NiCad drills. I've got the Makita a very good, strong and lightweight drill.
47_47 is offline   Reply With Quote
Old 02-22-2012, 12:14 PM   #5
Do u have the makita drill I mentioned above or a different makita? If it's the same one how have you found it to be when drilling masonary? Thanks
Old 02-22-2012, 12:27 PM   #6
47_47's Avatar
Rewards Points: 62
Same one. Only drilled 3/16" holes for small tapcons into concrete and it worked well.
Old 02-22-2012, 07:08 PM   #7
robertcdf's Avatar
Buy the makita, I have more makita drills than I can count.
robertcdf is offline   Reply With Quote
Old 02-22-2012, 08:49 PM   #8
DO IT RIGHT THE 1st TIME!
Makita since that is what is on your list. Milwaukee though is my personal preference.
Stay away from NiCad and go with Li-Ion
builttolast is offline   Reply With Quote
Old 02-23-2012, 04:22 AM   #9
Too Short? Cut it Again!
DeWalt used to be a trusted brand but something went horribly wrong. Lots of plastic housing, motor and transmission parts now. I would go with Makita of those you mentioned. Pick one that balances nicely and fits your hand if you can. If you have a tool rental place that has models you are considering, you might rent one for a test drive before buying although I suspect most places will let you return or exchange the drill. I bought tools from a tool supplier and not a box store when working. Among other things they carried higher end and more sturdy tools well worth a few extra bucks. They usually were willing to offer loaners if you had to have something serviced. Try asking for a loaner in a box store!
Ditto on Li-Ion batteries. NiCads have seen their day.
If you can find a model with a bubble level (or an available add-on option) it will come in handy for drilling straight holes.
Obviously you will want to invest in good masonry bits or the capabilities of the drill are wasted.
For a low end drill? I am continually surprised by Ryobi. They are what they are but at least the industrial design is nice. I don't know if they make a hammer drill and not sure I would trust things that far. It sounds like you plan to use this drill a lot and need a work horse.
Just one final comment. I love cordless tools but brick, especially antique masonry that has hardened, can be tough to get into even with a hammer drill and nice bits. Sure you do not want to explore a corded drill with consistent torque and hammer repitition? At least be sure you have extra batteries cycling through a charger.
Old 02-23-2012, 10:11 AM   #10
SDSESTER has it right on keeping batteries handy. TRY to get a model that includes the extended run time batteries, not sure what makita calls them - DeWalt calls them XRP, Milwaukee calls them XC and rigid calls them I think XR? Keep one on the charge and one in the drill while working masonry to avoid ranting and cursing when you get to the last 3 holes and all the drill does is go click
Old 02-23-2012, 07:18 PM   #11
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
...from the Links in Post #1;
1) The first candidate DeWalt Hammer Drill has two Nii-Cad, 1.3 Ah batteries.
2) The second DeWalt has one Li-Ion 2.0 Ah battery
3) The Makita Hammer Drill has one Li-Ion 3.0 Ah battery
The three submittals show that the price is most dependant on the quality and Ah size of the batteries. The Ah ratings have nothing to do with the power of the drill but just the run time. Batteries in the 3 Ah range are considered at the top of the range.
The choice between DeWalt/Makita should also depend on what will be your next cordless tool. Since the Battery is such a big part of a tools cost it's cheaper to keep follow on tools in the same family. If you have an add-on tool on your horizon, now might be the time to consider a multi tool Kit with two batteries. It will be cheaper in the long run.
Another consideration is what type Case is included; the three Links you posted are not clear as to whether or not the case is fabric or plastic. I prefer a plastic fitted case because it is easier to keep everything together in its own little niche and still have room for extra bits, also a case is neater to store than a bag.
Originally Posted by Homervanderjazz View Post
[FONT=&quot]........ but I am not sure whether I need something with more power......
Homer, Your previous Post on Drilling in Brick made me realize that I really did not know how long it took to drill a given size hole in brick. So with my 1st gen DeWalt 18V Hammer Drill DW997 I drilled a series of ” holes in a leftover brick from the top side, all the way through the brick(2”).
Results: 1st Test 65sec Drill set to low speed
...........2nd Test 30sec Drill set to high speed
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-26-2012, 11:21 AM   #12
re
Thanks for all the help folks, turns out I have had a bit of luck, I mentioned I needed a drill to a friend who said he was selling his drill- ended up buying it for 20 including battery and charger. It is a Ryobi cdi1801 18v, I know its not in the same league as the Makita etc but I have used it for a day now and even used it to drill into masonary and it has worked well. Hopefully it lasts a while. Thanks again for all the advice.
The Following User Says Thank You to Homervanderjazz For This Useful Post:
PaliBob (02-26-2012)
Old 02-26-2012, 11:56 AM   #13
Tool Geek
PaliBob's Avatar
Congratulations on your success and thank you for replying as to how you made out.
Disclaimer
& Stay Safe
.....Bob Lavery
DeWalt Drills TurboDIYer Tools 39 02-02-2012 07:04 PM
Dual Voltage Hammer Drills 1Khalid Tools 5 06-17-2011 03:41 PM
lithium ion drills superman120799 Tools 4 09-09-2010 06:52 PM
drills suswhi Building & Construction 1 07-26-2010 12:01 PM
Anybody work with numbered drills smaller than 0.0625"? Yoyizit General DIY Discussions 7 07-22-2010 01:15 PM
