Temporary Mount For My Bench Grinder - Tools - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 04:30 PM   #1
temporary mount for my bench grinder
Freed up some space on my bench today...I don't use my grinder all that much so I wanted a temporary set up. When not in use I store it on the bottom of a service cart...I can be up and grinding in under a minute...
My humble Man Blog
jasonreck71 is offline   Reply With Quote
The Following User Says Thank You to jasonreck71 For This Useful Post:
bbo (02-03-2012)
Old 02-03-2012, 07:50 PM   #2
Rewards Points: 192
I don't have a picture but I mounted mine on an old wooden bar stool and added a 25 lbs weight to the bottom rung. Works great.
bcgfdc3 is offline   Reply With Quote
Old 02-03-2012, 07:59 PM   #3
Rewards Points: 13,250
Piece of 3/4 Advantec with a 2 X 2 cleat on the bottom of it. Set it on A Black and Decker Work Mate. Far more sturdy then what you have in that picture.
Also works for using a skroll saw, planner, small band saw.
I rigged up an old Amour with shelve to store the tools when not in use.
Close the doors and no dust.
Old 02-03-2012, 08:17 PM   #4
bbo
i like the idea of multiple tools with their own base attached ...
bbo is offline   Reply With Quote
Old 02-03-2012, 08:20 PM   #5
Takes up less room in a small shop. Also easy to take them on site if needed.
Bench grinder Justins1171 Tools 3 01-30-2012 01:09 PM
Bench Grinder Justins1171 Tools 5 11-23-2011 09:21 PM
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 06:09 AM
Good bench grinder junkcollector Tools 0 10-07-2010 08:29 PM
20 amp circuit required for new bench grinder?? sdyck Electrical 6 04-05-2009 04:25 PM
