Taking Part A Laser Level - Tools - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 09:20 PM   #1
pwilson2011's Avatar
taking part a Laser Level
I spent some time pulling apart an old laser levels, and was trying to figure out if it has a Red laser diodes that are almost certainly the most typical kinds of diodes used in the lower end outdoor laser levels or perhaps a 630nm Helium-neon laser I'm sure the wave they work at either 650nm or 630 - 635nm probably not sure which one. I though it would be an open diode but it really appears like it is closed since these have some form of casing around the diode which means at least it has some protection.
The beam of light is real small and intense Maybe its a diode pumped solid state laser (DPSS) - I do believe these laser beams work at more or less 670nm or 680nm. They've got higher beam quality and narrower spectral bandwidth. Overall the standard and brightness is a lot more finer than the lower nm beams. xxxxxxxxxxxx shoot a beam of light that can be used as a visible chalk line whenever a direct and even location point is required.
The size for the beam of light will depend on the size of the diode. In this instance, smaller is much better a smaller beam of light is extra precise. Having a wider beam of light, the actual point of "level" may be placed anywhere inside the width of the ray. So I think because of this, thxxxxxxxxx is so little and presice in order to get a very precise measurement.
Right now I've the laser diode out of the casing I now need to choose what I'm going to do with it now I have it, I want think of a entertaining mission to get my teeth into, has anyone made some cool and entertaining stuff with a extra construction laser level beam
pwilson2011 is offline   Reply With Quote
Old 09-30-2011, 09:57 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
you can make a low lever laser treatment for erectile dysfunction
check out instructables.com they have all kinds of cool projects ( and this one^ too)
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Tags
laser level
Tub Flange and level tiling DIY Girl Kitchen & Bath Remodeling 2 09-14-2011 08:58 AM
How 'level' is level? BOUTYM Flooring 2 09-04-2011 06:30 PM
level or not level toilet? ron0805 Plumbing 4 10-26-2009 05:16 PM
Ground level deck Daddyshammer Building & Construction 56 09-13-2009 08:58 PM
Q about Humidity Level... Okay for Wood Floor? Ininkus Flooring 8 01-23-2009 10:58 AM
