Table Saw Acc. - Tools - DIY Chatroom Home Improvement Forum
Old 12-04-2008, 11:28 AM   #1
Table saw acc.
I bought a craftsman 10" table saw. Model # 22124 and i am looking for a riving knife that would fit this model. Craftsman doen't make one for trhis saw and does anby one know of an after market one? thanks for any help.
nickol@comcast.net is offline   Reply With Quote
Old 12-04-2008, 01:38 PM   #2
(the original)
Rewards Points: 756
There's no such thing as an aftermarket or add-on riving knife. The riving knife is incorporated into the arbor assembly, so the whole assembly would have to be replaced. As I understand it, starting next year UL will require that all new table saws be equipped with a riving knife, so maybe at some point in the future some of the manufacturers might start making a retrofit available. If they do, I guarantee it won't be cheap....
ratherbefishin' is offline   Reply With Quote
Old 12-04-2008, 02:39 PM   #3
Registered User
Termite's Avatar
If you make your own zero clearance inserts for your tablesaw from birch plywood, a wooden splitter can be incorporated into that. Less durable of course, but better than nothing.
Old 12-04-2008, 03:50 PM   #4
(the original)
Rewards Points: 756
Yup, termite's right. Or if you're willing to drop a few bucks you can get a phenolic insert and a steel or polycarbonate splitter kit that'll last just about forever
Splitters are only good for 90 degree cuts, though. If kickback is your concern, featherboards are a really good addition to your saw. In fact, they're good anyway for the sake of accuracy. I usually use one mounted in the miter gauge slot for cuts that need to be precise and add a vertical featherboard on the fence when I have to do long rips. I don't like flying boards.....one hernia surgery was enough
Old 12-05-2008, 10:13 AM   #5
RippySkippy's Avatar
Looks like that model like many early craftsmans were a part of the blade guard. If it's got the guard, your in luck...put it back on and your set. If you don't have it...I'm sure it's obtainable via sears parts...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Shutoff switch for custom Router Table. mfleming Electrical 14 11-13-2008 01:50 PM
Pool Table on Floating Hardwood Q......... tigerbalm2424 Flooring 4 07-28-2008 09:09 AM
Looking for Japanese dining room table plans dantefontana Carpentry 3 03-01-2008 09:11 PM
Need Advice for Adding Wheels to Table HandyDottie Carpentry 7 01-27-2008 08:44 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 09:47 AM
