-   Tools (http://www.diychatroom.com/f29/)
-   -   Table saw acc. (http://www.diychatroom.com/f29/table-saw-acc-33144/)
nickol@comcast.net 12-04-2008 10:28 AM
Table saw acc.
I bought a craftsman 10" table saw. Model # 22124 and i am looking for a riving knife that would fit this model. Craftsman doen't make one for trhis saw and does anby one know of an after market one? thanks for any help.
ratherbefishin' 12-04-2008 12:38 PM
There's no such thing as an aftermarket or add-on riving knife. The riving knife is incorporated into the arbor assembly, so the whole assembly would have to be replaced. As I understand it, starting next year UL will require that all new table saws be equipped with a riving knife, so maybe at some point in the future some of the manufacturers might start making a retrofit available. If they do, I guarantee it won't be cheap....:(
Termite 12-04-2008 01:39 PM
If you make your own zero clearance inserts for your tablesaw from birch plywood, a wooden splitter can be incorporated into that. Less durable of course, but better than nothing.
ratherbefishin' 12-04-2008 02:50 PM
Yup, termite's right. Or if you're willing to drop a few bucks you can get a phenolic insert and a steel or polycarbonate splitter kit that'll last just about forever:yes:
Splitters are only good for 90 degree cuts, though. If kickback is your concern, featherboards are a really good addition to your saw. In fact, they're good anyway for the sake of accuracy. I usually use one mounted in the miter gauge slot for cuts that need to be precise and add a vertical featherboard on the fence when I have to do long rips. I don't like flying boards.....one hernia surgery was enough:eek:
RippySkippy 12-05-2008 09:13 AM
Looks like that model like many early craftsmans were a part of the blade guard. If it's got the guard, your in luck...put it back on and your set. If you don't have it...I'm sure it's obtainable via sears parts...
