Table Saw - Tools - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 06:49 PM   #1
Table Saw
I Might Be in the wrong area, If so I am sorry, But I need some Info On some TS. I am Looking to spend in the 750 / 850 Dollars range. And would I need a Bekt drive or Direct Drive, also I need to stay with 110. What you like about the Saw you suggested. And I would like one with a Great Fence, Or I would deduct from and But a Good One.
splinter2 is offline   Reply With Quote
Old 04-17-2013, 07:56 PM   #2
An old Tradesmen
Rewards Points: 6,550
Moved to Tool forum.
Old 04-19-2013, 05:40 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by splinter2 View Post
.....I am Looking to spend in the 750 / 850 Dollars range.....
I would classify that as a mid-range saw. You may get more responses on the Woodworking Tool Forum.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-19-2013, 09:49 AM   #4
Rewards Points: 13,300
http://www.ridgid.com/Tools/10-Cast-...w/EN/index.htm
http://www.grizzly.com/products/10-H...Series-/G0715P
http://www.jettools.com/us/en/p/delu...0-rip/708676PK
Old 04-19-2013, 10:12 AM   #5
DIY staff
Rewards Points: 7,174
You are on the right track----Belt drive----best fence you can afford----I have a Grizzly cabinet saw and am pleased with their customer service---
Do consider a used unit----
Old 04-19-2013, 05:30 PM   #6
Rewards Points: 5,974
Most come with an OK fence and anOK blade no matter whice one you choose these would be my first 2 upgrades.
Old 04-19-2013, 11:55 PM   #7
Floor Installer
sam floor's Avatar
Rewards Points: 154
I have a Craftsman cabinet saw. It was about $1000, but is an excellent saw and has a Biesemeyer fence. You can't beat that fence.
sam floor is offline   Reply With Quote
Old 04-20-2013, 07:51 AM   #8
Bosch make a great portable that has a strong motor and a great stand and fence.
jessrj is offline   Reply With Quote
Old 04-20-2013, 09:22 AM   #9
You don't say how much room you have. A cabinet saw is the best but takes up quite a bit of room. Next is a contractors saw it is smaller but mobile and can be wheeled out of the road if need be. The down side is you loose a lot in the footprint in other words the top is a lot smaller, an out feed table is a must if you plan on cutting any sheet goods or long materials. And unless you plan on moving it a lot like job site to job site or room is such a problem that you have to fold it and stand it in a corner between uses I would not consider a portable. The table is so small it is considered dangerous by some for cutting large pieces unless you have a helper. These are only my opinions and I'm sure some will disagree.
Old 04-24-2013, 03:25 PM   #10
In a little over my head
Rewards Points: 706
ToolSeeker said it. Cabinet saw if you have the room. You could put it on a mobile base, too. Contractor's saw if you need someting smaller. Portable if you are really short of space (as I am). One more thing; it may be tough to find a cabinet saw that runs on 110.
There's a new style, called a hybrid, that may be best. Motor's inside like a Cabinet, rather than hanging off the back like a Contractor's. But the cabinet doesn't go all the way to the floor, and the motor's usually 110.
ratherbefishing is offline   Reply With Quote
Old 04-24-2013, 03:32 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,148
I have the Ryobi table saw....love it...I can mount a router on the side table and use the same rip fence....
ddawg16 is online now   Reply With Quote
Old 04-24-2013, 08:43 PM   #12
Rewards Points: 127
I bought the rigid. It cost about $700, and has been quite good.
ptarmigan61 is offline   Reply With Quote
Old 04-24-2013, 08:50 PM   #13
I also have the Ridgid and am happy with it. But almost every day I wish I had the room for a new Delta big boy.
DIY Table Saw vs Ready-Made Table Saw ?? CaptainMarvel Tools 19 01-15-2013 08:21 AM
Can a Birch wood table be used outside on deck if treated or sealed? mafmmx General DIY Discussions 3 04-08-2012 04:11 PM
10" table saw or compound mitre saw - which would you choose? whataboutj Tools 9 12-03-2011 04:13 PM
Tressle table - how to build? Knucklez Carpentry 1 10-24-2009 04:18 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 09:47 AM
