-   Tools (http://www.diychatroom.com/f29/)
-   -   Table Saw (http://www.diychatroom.com/f29/table-saw-177401/)
splinter2 04-17-2013 05:49 PM
Table Saw
I Might Be in the wrong area, If so I am sorry, But I need some Info On some TS. I am Looking to spend in the 750 / 850 Dollars range. And would I need a Bekt drive or Direct Drive, also I need to stay with 110. What you like about the Saw you suggested. And I would like one with a Great Fence, Or I would deduct from and But a Good One.
beenthere 04-17-2013 06:56 PM
Moved to Tool forum.
PaliBob 04-19-2013 04:40 AM
Originally Posted by splinter2 (Post 1161380)
.....I am Looking to spend in the 750 / 850 Dollars range.....
I would classify that as a mid-range saw. You may get more responses on the Woodworking Tool Forum.
joecaption 04-19-2013 08:49 AM
http://www.ridgid.com/Tools/10-Cast-...w/EN/index.htm
http://www.grizzly.com/products/10-H...Series-/G0715P
http://www.jettools.com/us/en/p/delu...0-rip/708676PK
oh'mike 04-19-2013 09:12 AM
You are on the right track----Belt drive----best fence you can afford----I have a Grizzly cabinet saw and am pleased with their customer service---
Do consider a used unit----
ToolSeeker 04-19-2013 04:30 PM
Most come with an OK fence and anOK blade no matter whice one you choose these would be my first 2 upgrades.
sam floor 04-19-2013 10:55 PM
I have a Craftsman cabinet saw. It was about $1000, but is an excellent saw and has a Biesemeyer fence. You can't beat that fence.
jessrj 04-20-2013 06:51 AM
Bosch make a great portable that has a strong motor and a great stand and fence.
ToolSeeker 04-20-2013 08:22 AM
You don't say how much room you have. A cabinet saw is the best but takes up quite a bit of room. Next is a contractors saw it is smaller but mobile and can be wheeled out of the road if need be. The down side is you loose a lot in the footprint in other words the top is a lot smaller, an out feed table is a must if you plan on cutting any sheet goods or long materials. And unless you plan on moving it a lot like job site to job site or room is such a problem that you have to fold it and stand it in a corner between uses I would not consider a portable. The table is so small it is considered dangerous by some for cutting large pieces unless you have a helper. These are only my opinions and I'm sure some will disagree.
ratherbefishing 04-24-2013 02:25 PM
ToolSeeker said it. Cabinet saw if you have the room. You could put it on a mobile base, too. Contractor's saw if you need someting smaller. Portable if you are really short of space (as I am). One more thing; it may be tough to find a cabinet saw that runs on 110.
There's a new style, called a hybrid, that may be best. Motor's inside like a Cabinet, rather than hanging off the back like a Contractor's. But the cabinet doesn't go all the way to the floor, and the motor's usually 110.
ddawg16 04-24-2013 02:32 PM
I have the Ryobi table saw....love it...I can mount a router on the side table and use the same rip fence....
ptarmigan61 04-24-2013 07:43 PM
I bought the rigid. It cost about $700, and has been quite good.
ToolSeeker 04-24-2013 07:50 PM
I also have the Ridgid and am happy with it. But almost every day I wish I had the room for a new Delta big boy.
