Table Capacity Makita LS1016L - Tools - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 06:36 PM   #1
Jai
Table capacity Makita LS1016L
I recently picked up a used LS1016L specifically to cut baseboard and crown for a remodeling project. I like the LS1016L because I can cut vertically or horizontally, depending on size. For baseboard I'm using 5 1/4 stock lying flat on the saw deck. The saw doesn't extend backwards to complete the cut but all four rails seem to be fully extended. I checked the manual and didn't anything covering this issue. Has anyone else seen this before with this model Makita? I should mention this is my first slider. It's a little more detailed than the chop saw I've been using.
Jai is offline   Reply With Quote
Old 02-12-2012, 07:14 PM   #2
Rewards Points: 12,818
http://www.makita.com/en-us/Modules/...x?Name=LS1016L
Old 02-13-2012, 02:21 PM   #3
I have it's predecessor the 1013! The 1016 I believe has 4 rails the saw moves on making it more ridgid and accurate! IMHO you got the best slider out there!
toolaholic is offline   Reply With Quote
Old 02-13-2012, 08:13 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
sounds like you didnt remove all of the packing from the saw or the depth stop's are engaged.. the saw should be able to cut this no problem.. check the saw again.
woodworkbykirk is offline   Reply With Quote
Standard or Sliding Mitre Saw? Or table saw? 7.62 Tools 18 05-07-2012 09:53 AM
10" table saw or compound mitre saw - which would you choose? whataboutj Tools 9 12-03-2011 04:13 PM
Review: Makita LS1016L Compound Sliding Mitre Saw and Makita 2704 Table Saw w/ Stand wnabcptrNH Tools 6 02-21-2010 07:52 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 09:47 AM
