Stubborn Hex Bolt - Tools - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 03:35 PM   #1
Stubborn Hex Bolt
I am taking apart my dryer and there are two hex bolts that holds the front of it together. It looks similar to this:
http://www.boltdepot.com/images/catalog/lag-bolt.gif
The other bolt I can turn to listen it but it never pulls out at all. Any tips on how to get this sucker out of there?
Slagwag is offline   Reply With Quote
Old 01-07-2012, 03:39 PM   #2
Rewards Points: 13,978
Not sure why your trying to take the front off at all. Any I've seen are worked on from the top or the back side.
Lefty loosy.
Old 01-07-2012, 03:47 PM   #3
Definitely going left.
http://www.repairclinic.com/Dryer-Ga...liance-Diagram
I am using that site on how to open the dryer so I can replace the belt. The front panel has two screws to the top that are required to come off so that the front can pop off.
Old 01-07-2012, 08:25 PM   #4
In a little over my head
Rewards Points: 706
The hole's stripped. Get a putty knife, nail puller, knife blade, whatever behind the head and give a little outward pressure while you turn. It'll come right out.
ratherbefishing is offline   Reply With Quote
Old 01-07-2012, 08:44 PM   #5
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Or vise grips; pull outwardly while you turn counter clockwise.
(kind of like a counter-rotating glokinspheel)
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Specialty bolt - Lag bolt with attached coupling nut? 5thumbs Building & Construction 6 08-22-2011 01:08 PM
Toggle / anchor bolt question masada Drywall & Plaster 3 07-06-2011 12:39 PM
Need Hex Bolt for Older Velux Skylight xquercus Roofing/Siding 0 05-26-2010 01:19 PM
How to remove sheared off bolt ptcity General DIY Discussions 3 04-17-2009 09:28 PM
Attach a bolt to drywall hdayanan Building & Construction 1 03-17-2006 07:01 AM
