String Trimmer - Tools - DIY Chatroom Home Improvement Forum
Old 03-18-2012, 11:27 AM   #1
Rewards Points: 768
String trimmer
Looking to get one. Would like to stay under $200, but didn't know if the 4 cycles were worth the extra...also wondered your thoughts on the curved or straight shaft...??
cibula11 is offline   Reply With Quote
Old 03-18-2012, 01:01 PM   #2
Rewards Points: 13,250
What brand to you see most pro lawn maintaince companys using?
Give up?
http://www.stihlusa.com/trimmers/
And there made in the USA.
I also have a 4 stroke Homelite that has plenty of power, always starts, and makes less noise when running then a 2 stroke. It does use a lot of oil so you have to check it every time you use it.
A straight shaft is the way to go, no heavy duty line trimmer will have a curved shaft. A straight shaft also keeps you further away from where your working.
Old 03-20-2012, 12:09 AM   #3
In a little over my head
Rewards Points: 706
3 or 4 years ago, I needed a new string trimmer. I asked my brother in law, who owns a landscaping biz, what to buy. He said Echo. So I bought an Echo with the interchangeable implements. Got the trimmer and the edger. Works great. No complaints.
ratherbefishing is offline   Reply With Quote
Old 03-20-2012, 08:54 AM   #4
joed's Avatar
Rewards Points: 11,966
Straight shaft for me. I can't use the bent shaft ones.
Old 03-20-2012, 11:09 AM   #5
Rewards Points: 768
Well, I saw a deal on craigslist that I couldn't pass up. It's a 4 cycle troy bilt trimmer.. It has the curved shaft, but for $20, I figured it was worth it.
Old 03-20-2012, 04:12 PM   #6
Rewards Points: 706
Sounds like you either got a great deal, or threw away a little bit of money.
If it starts and runs, you got a deal.
Old 03-25-2012, 03:06 PM   #7
Rewards Points: 768
Works great....although I just spent $8 on new fuel lines...the old ones were cracked...but other than that it's been just find. Now if I convince my wife that i saved us $150 I could buy something else
Old 03-26-2012, 09:44 AM   #8
Rewards Points: 706
That's just good logic.
Grass Trimmer options? BlackEagle Landscaping & Lawn Care 10 07-16-2011 03:13 PM
String Trimmer won't run scottj963 Landscaping & Lawn Care 1 07-11-2011 03:52 AM
Ryobi string trimmer cgoll Landscaping & Lawn Care 0 06-15-2011 04:13 PM
Repair help w/ a cordless trimmer kennykenny Tools 6 06-28-2009 09:20 PM
Pulling in Flex eNt (vacuum string?) jamiedolan Electrical 7 03-05-2009 12:36 PM
