Standby Generator Problem - Tools - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 07:12 PM   #1
Standby generator problem
My Generac generator gives a "low oil" signal & shuts down. I have changed oil & filter, replaced sending unit. When resetting & running in 'manual", it will run for 5 min, then again for 10 min before shutting down. It will run continously if I set it on "manual" on third or fourth try. Engine not knocking or noisy. It has to be in electrics or electronics, maybe?
NCWGNMKR is offline   Reply With Quote
Old 03-11-2012, 11:43 PM   #2
Missouri Bound's Avatar
Does that unit have an electronic control board? I'd contact Generac for their input. If the sensor is bad it woulnd't run....or basically shouldn't start at any setting manual or auto.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
NCWGNMKR (03-13-2012)
Old 03-13-2012, 12:36 PM   #3
I'll see what Generac recommends, again, thanks
Standby generator on/off switch Jeremy Hillary Boob, PhD Electrical 27 12-14-2014 03:18 PM
standby generator installation cost newhomenj Electrical 54 12-26-2012 08:16 PM
standby generator masanori Electrical 0 02-16-2012 03:43 PM
Standby Generator & Transfer Switch JRoot Electrical 9 06-12-2011 10:14 AM
Definition standby power vs emergency power 8 Ball Electrical 2 09-06-2008 06:19 AM
