Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 08-15-2012, 09:16 AM   #1
Spark at end of brad nailer
I was installing baseboard molding the other day using a brad nailer (1 1/4 inch brads). I could see the screws in the studs under the seam tape so I placed pieces of masking tape on the floor adjacent to where the screws were and put the brads in the corresponding places. Of course, the last brad I popped in sparked at the end of the brad nailer. The breaker didn't trip, I didn't hear a pop or smell any electrical burning. I hope I didn't hit an electrical wire and didn't think so, especially using such a small brad. Should I be concerned? Thanks.
RK76 is offline   Reply With Quote
Old 08-15-2012, 10:33 AM   #2
Not likly it was a wire but anything's possible.
I'd concider playing it safe and pull the base and check it out. You should be able to just cut a hole below where the base is going to sit to peek in.
I've hit a wire with a Tow Kick saw cutting out a floor. Someone had ran the wire through the bottom plate at such an angle in a notch instead of a hole that it the wire looked like a Z and was out behond the drywall.
A tip for next time instead of wasting tape and time. Mark the floor with one piece of tape near a corner, pull out your measuring tape and lay it on the floor out away from where you need to nail, if the studs line up with the 16" on center marks use that as your guide for nail placement instead of marking every stud.
Old 08-15-2012, 11:09 AM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Sometimes nailers will spark, when the rod hits the nail. Even better with the framing nailers. Nothing toneorry about.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 09-01-2012, 03:37 PM   #4
Bombastic Idiot
notmrjohn's Avatar
greg, I say that if RK, in celebration of finally driving that last brad, wants to toneorry about, then let him toneorry about. Fetch the jesters, play the internal organs, pipe ye sandpipers! Let us all toneorry about in glee.
notmrjohn is offline   Reply With Quote
Old 09-01-2012, 07:22 PM   #5
if your baseboard is 1/2 inch thick and the drywall is 1/2 inch thick 1-1/4 brads are not gonna hold your baseboard on.
Old 09-01-2012, 07:40 PM   #6
It's suppost to spark, so you can stick weld the two pieces together.
Only kidding.
Old 09-02-2012, 11:21 AM   #7
AHH, SPANS!!!
chances are the spark was from the nail plunger in the tip of the brad nailer ricocheting off the side of the brad during insertion, I see it all the time. if you examine the nail hole where the brad entered it will probably be larger than the other nail holes or shaped oblong as opposed to round.
hand drive is offline   Reply With Quote
Brad Nailer problem jfile Tools 1 05-11-2011 11:15 PM
Do I need a Brad or Finish Nailer? atm Carpentry 13 03-10-2010 11:43 PM
Brad Nailer vs. Finishing Nailer tripower Building & Construction 6 11-17-2009 06:05 AM
Installing Bamboo Flooring with Brad Nailer? aaks38 Flooring 3 11-04-2008 10:11 AM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 07:55 AM
