Spade Bits - Tools - DIY Chatroom Home Improvement Forum
Old 11-26-2006, 07:51 PM   #1
Spade Bits
ANyone had any luck sharpening spade drill bits?
oddjob is offline   Reply With Quote
Old 11-26-2006, 07:56 PM   #2
World famous jerk.
They're so cheap, it's not really worth the labor it takes to sharpen them. What do they cost... 2 dollars?
mdshunk is offline   Reply With Quote
Old 11-26-2006, 08:16 PM   #3
General Contractor
joasis's Avatar
And if you get one edge "steeper" then the other, you would have the potential to cause a lot of tearout of material, as if there isn't a lot already....keep in mind, drills (all drills) wear on the sides as well as the cutting edges....by the time a spade drill is dull, the sides of the spade would also be slightly rounded and it will not perform satisfactorily.
joasis is offline   Reply With Quote
