-   Tools (http://www.diychatroom.com/f29/)
-   -   Spade Bits (http://www.diychatroom.com/f29/spade-bits-5033/)
oddjob 11-26-2006 07:51 PM
Spade Bits
ANyone had any luck sharpening spade drill bits?
mdshunk 11-26-2006 07:56 PM
They're so cheap, it's not really worth the labor it takes to sharpen them. What do they cost... 2 dollars?
joasis 11-26-2006 08:16 PM
And if you get one edge "steeper" then the other, you would have the potential to cause a lot of tearout of material, as if there isn't a lot already....keep in mind, drills (all drills) wear on the sides as well as the cutting edges....by the time a spade drill is dull, the sides of the spade would also be slightly rounded and it will not perform satisfactorily.
