Are Some Drill Bits Better For Mechanical (metal) Work Than Others? - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-09-2014, 10:31 PM   #16
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,460
Originally Posted by 4reel View Post
Speed is another important factor. The faster the bit the higher the heat. Heat destroys temper in drill bits.
Basically, your getting higher friction verse cutting.
MTN REMODEL LLC is offline   Reply With Quote
Old 04-13-2014, 08:28 PM   #17
Rewards Points: 4,784
Originally Posted by amakarevic View Post
the Lowe's house brand ?
That is Kobalt (aggravating when people misspell these things. Lowes brand is Kobalt, not Cobalt. Home Depot brand is Ridgid, not Rigid.)
You will usually see cobalt (for metal drilling), titanium (stronger and stay sharper than black oxide), and black oxide (the cheapest).
jeffnc is offline   Reply With Quote
Old 04-14-2014, 10:28 PM   #18
Rewards Points: 118
Actually it doesn't bother me at all when the brand names get Ellen wrong, easy enough normally to understand what people mean. Bosch is Bosh, I still know what it means. Cobalt vs Kobalt would be the exception!
To the op, I USED to buy "the best" drill bits but found that for my purposes, medium quality was just fine. Especially in the smaller sizes, 1/8, etc.,you will break the eensive ones as quickly as the cheap ones. So in general I try to match the bit with what I need. That is, if I need to drill a 1/4 inch hole through stainless steel, I could end an hour and kill several cheap drill bits where a cobalt (maybe Kobalt also, but cobalt metal tip) will just zip through. If I am doing wood, crap holes are spade bit while finish holes are forstner bits. Ron
ront02769 is offline   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
MTN REMODEL LLC (04-14-2014)
Old 04-20-2014, 11:51 PM   #19
1968 Ranch
Ive been a machinist for 20 years, I also have my own shop.
You always want to look for HSS, next thing is if its surface heat treated (garbage). Most cheaper drills will be coated and surface heat treated. Your correct about cutting oil and low rpm. The step drill works great in thin material (thinner then step of drill).
Sent from my SCH-R530U using Tapatalk
Electromech31 is offline   Reply With Quote
Tags
drill bit
I need some help drilling into a metal bolt amodoko Tools 30 03-15-2015 12:22 PM
I feel dumb - how to attach something to metal Zephie General DIY Discussions 3 07-11-2012 07:37 AM
Drill bits james2012 Building & Construction 3 07-07-2012 11:35 PM
Black oxide drill bits on metal dasjambo Tools 2 08-15-2011 01:21 PM
isolating noise transmission in metal duct work BrandonHook HVAC 2 12-07-2008 07:37 AM
