Are Some Drill Bits Better For Mechanical (metal) Work Than Others? - Tools - DIY Chatroom Home Improvement Forum
Old 04-08-2014, 03:59 PM   #1
Rewards Points: 1,062
Question
Are some drill bits better for mechanical (metal) work than others?
I am looking to buy a set of high quality metal drill bits. Usually, drill bits out there on the market are not classified for metal vs. wood and other softer materials. Are some drill bits better for automotive work and metal applications than others?
Old 04-08-2014, 04:02 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Cobalt
MTN REMODEL LLC is offline   Reply With Quote
The Following 2 Users Say Thank You to MTN REMODEL LLC For This Useful Post:
amakarevic (04-08-2014), cyberknight (04-08-2014)
Old 04-08-2014, 04:03 PM   #3
Question
Originally Posted by MTN REMODEL LLC View Post
Cobalt
the Lowe's house brand ?
Old 04-08-2014, 04:11 PM   #4
Ya know.... I'm really not sure..... Cobalt is an additive/alloy in the bit, and I do not know for certain, but I think there are different qualities of cobalt steel...
I don't know how you would know that quality... but I would suspect that Lowes probably carries a HO low/med type quality.
Just my guess
Old 04-08-2014, 04:20 PM   #5
Rewards Points: 13,260
In order of the worst to the best.
High speed steel.
Titanium nitride coated.
Cobalt.
Old 04-08-2014, 04:22 PM   #6
Oso954's Avatar
Rewards Points: 740
Kobalt is Lowe's own brand of tools.
Cobalt is an element or refined metal.
Oso954 is offline   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
amakarevic (04-08-2014), MTN REMODEL LLC (04-08-2014)
Old 04-08-2014, 04:39 PM   #7
here we go: http://www.amazon.com/gp/product/B0000TZX3A/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Old 04-08-2014, 05:05 PM   #8
Rewards Points: 690
Drill Bits
Both Cobalt and HSS ( high speed steel ) will work but when drilling steel don't forget that a drop or two of cutting fluid every second or two works wonders with either of those two mentioned. Search cutting fluid for your favorite. Amazon has it too.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 04-08-2014, 10:26 PM   #9
Oh... Thanks OSO.... never thought of that... I thought OP was looking at a set of cobalt bits at Lowes..........forgot that was their store branding.
Old 04-08-2014, 10:28 PM   #10
And slow speed and a drill press......
Old 04-09-2014, 10:26 AM   #11
Rewards Points: 29
Do not forget lubricant when drilling. The heat is what kills the drill. The lubricant is really there to cool the bit.
4reel is offline   Reply With Quote
Old 04-09-2014, 11:56 AM   #12
Rewards Points: 1,442
Also, for metal, the stepped up bits work nicely. You could also just start small and work your way up.
mikegp is offline   Reply With Quote
Old 04-09-2014, 01:51 PM   #13
I just had to drill a SS sink for a center mount faucet..1 3/8 hole.
SS is very hard.... and sure do not have a 1 3/8 cobalt bit.
Started the hole with a 1/4 cobalt twist.... and then went to a step bit to go out to 1 3/8.
The step bit was just a titanium coating not cobalt.
Not sure why it worked so well after starting with a pilot hole.
Old 04-09-2014, 05:29 PM   #14
Oso954's Avatar
Rewards Points: 740
Any time you are cutting or drilling hard metal, a little bit at a time works better than going the big bite.
Before step bits, it was common practice to drill holes 1/8 inch at a time with a bit change between every 1/8.
Still done that way for thicker materials with deep holes.
Old 04-09-2014, 06:11 PM   #15
Rewards Points: 29
Speed
Speed is another important factor. The faster the bit the higher the heat. Heat destroys temper in drill bits.
Tags
drill bit
I need some help drilling into a metal bolt amodoko Tools 30 03-15-2015 12:22 PM
I feel dumb - how to attach something to metal Zephie General DIY Discussions 3 07-11-2012 07:37 AM
Drill bits james2012 Building & Construction 3 07-07-2012 11:35 PM
Black oxide drill bits on metal dasjambo Tools 2 08-15-2011 01:21 PM
isolating noise transmission in metal duct work BrandonHook HVAC 2 12-07-2008 07:37 AM
