Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 01-01-2008, 02:25 PM   #1
snow plow will not propel itself
I have a dual stage snow blower (Craftsman model C950-52131-0) and the unit will not propel itself. I have checked the drive belt, the traction drive cable and the friction disc. They all seem to be ok. Any ideas on what the problem could be?
mrbowma is offline   Reply With Quote
Old 01-03-2008, 04:28 PM   #2
Res Ipsa Loquitur
If the engine is running well, the blades are spinning yet the machine isn't moving, it may have a shear pin that cut off or the clutch isn't working properly. For the shear pin, look to see where the last part of the machine is turning with regard to the drive axle. A shear pin works like a nut and bolt would to attach a gear to a round shaft. It is just meant to break away to prevent damage. Mine has a belt drive from the engine to the gearbox and a chain drive from the gearbox to the drive axle (using a shear pin). For the clutch you need to investigate how the clutch works on that model. It should grab a spinning flywheel when engaged.
handyman78 is offline   Reply With Quote
Old 01-03-2008, 05:12 PM   #3
Handyman78....we will check those things....
Snow Blower Pull doesn't have tension Camper147 Tools 14 02-02-2012 05:59 AM
snow build-up on plow timber General Discussion 4 01-02-2008 09:17 AM
Ice issue - even after improving ventilation andy1896 Roofing 13 12-13-2007 12:50 AM
Adding a snow supporting arbor snmhanson Building & Construction 2 12-15-2006 07:21 PM
