Snapper Snow Blower - Tools - DIY Chatroom Home Improvement Forum
Old 12-22-2009, 03:24 PM   #1
Snapper Snow Blower
How do you replace belts on a dual stage 10HP Snapper snow blower? I took off inspection cover. How to you remove the shaft to get the new belts on? Where do you separate?
craigconner is offline   Reply With Quote
Old 12-22-2009, 04:08 PM   #2
47_47's Avatar
Rewards Points: 44
For the larger snow blowers I've worked on, there are 4 bolts (2 per side and by the drive wheels) which hold the front and rear assemblies together. You need to remove the top bolt on each side and loosen the bottom one to allow the two halves to split. Be careful not to damage your cables. Once split you may have to unbolt an idler pulley, remove a cable...
You should try an get a manual online to confirm.
47_47 is offline   Reply With Quote
Old 12-23-2009, 08:59 PM   #3
Mine had 3 bolts per size. Its saperates the engine and impeller snow thrower section apart. The drive belt has to be moved to saperate them.
note if you decide to drop it from the top do not their is a brake setup which the belt has to go under.this can only can be done when the things are saperate.If not the belt will shread it 2 minutes.
its very simple.
satz is offline   Reply With Quote
Yard Machines Snow Blower asian432003 Landscaping & Lawn Care 13 09-10-2009 10:38 PM
MTD Snow Blower w/Tecumseh Engine Won't Start RonZarn Tools 6 09-06-2009 08:35 PM
How close to the ground should the blades of my snow blower be? J187 Landscaping & Lawn Care 2 01-28-2009 04:53 PM
Snow Blower problem gregryan999 General DIY Discussions 2 02-14-2008 01:55 PM
any tricks to re-string pull starter on snow blower? whwestman General DIY Discussions 4 01-14-2008 05:29 PM
