Small Nose Nail Guns - Tools - DIY Chatroom Home Improvement Forum
Old 10-29-2007, 05:33 PM   #1
small nose nail guns
I am installing glass channel in a 1929 Franklin. I think a nail gun would help, since otherwise it takes about four hands. The glass channel accepts at most something 1/4" wide. I need a nail gun that handles 18 gauge headed nails 5/8" - 3/4" long, and has a nose 1/4" wide. I have looked at a Paslode gun that would work if the piece on the nose for automatic operation could be removed, so that the gun operated by trigger only. Unfortunately I cannot see how to remove this without destroying the gun. Are there any guns with noses narrow enough, or with removable detents on the nose? Any advice?
John L. Lumley is offline   Reply With Quote
Old 11-15-2007, 10:00 AM   #2
Spyko's Avatar
I'm not sure of the configuration of the gun you're looking at, but I have a small nailer that I modified by grinding the safety spade down to almost nothing. The safety still works and the mark it leaves is alot smaller now. If it's a wire bail type safety you might try removing it for the one job or cutting part of it away & bending it so it's out of you way but still functions. On most guns these are replaceable parts. If you remove it just be careful, and put it back right away!!
Spyko is offline   Reply With Quote
Old 11-15-2007, 02:25 PM   #3
PK.
Try a 23 ga. brad nailer. I think the Nikle shoots both pins and brads.
PK. is offline   Reply With Quote
Old 11-16-2007, 12:12 AM   #4
Spyko's Avatar
The 23 gauge pins are headless, and 18 gauge with heads were specified, no?
Old 11-16-2007, 04:29 PM   #5
PK.
Nope. You can now get a 23 ga brad nailer. I have a pin nailer and use it all the time. The 23 ga. brad nails are supposed to be great and I've asked Santa for one.
Not everybody makes them though. At least not yet.
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 10:42 AM
buying a nail gun with compressor Dave777 Tools 9 11-28-2011 12:37 AM
Using nail gun on deck fence? darsunt Carpentry 1 05-01-2007 09:11 AM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 11:38 AM
Nail Gun and Compressor - Help! MelindaA Carpentry 7 08-15-2006 09:17 AM
