Skilsaw Issue: Can't Tighten Blade - Tools - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 04:12 PM   #1
Rewards Points: 42
Skilsaw issue: can't tighten blade
Hi,
My trusty 5350 Skilsaw, which I've had for over 30 years, seems to have an issue. The motor runs but I can't tighten the blade securly on since the shaft still turns. Is the bearing flange bad? I cleaned both supporting discs (which hold the blade). What prevents the shaft from moving? Maybe I'm doing something wrong?
Thanks, MRivney
mrivney is offline   Reply With Quote
Old 11-04-2011, 04:51 PM   #2
DIY staff
Rewards Points: 7,174
Skil 5350 Parts List and Diagram - Type 1 (F012535000) : eReplacementParts.com
Here is a diagram---I don't have an answer but this may help you or someone else here to spot the worn part.--Mike---
mrivney (11-04-2011)
Old 11-04-2011, 07:04 PM   #3
just a tool guy
mickey cassiba's Avatar
The jack shaft(the arbor you mount the blade on)has been pulled out of it's normal position. This happens from time to time on a lot of circular saws. Usual causes are mounting a blade without the inside flange and actually pulling the jack shaft out when attempting to tighten the blade. Over-tightening is a major culprit, especially with today's thinner blades. A thirty year old saw may also have wear on the inside face of the gearbox cover. This is normal no matter how careful you are with the tool. A quick check is this: Remove the flanges, blade and nut and clean up the shaft. Get all the grease and gunk off, and dry it off well. Then scribe or draw a mark on the shaft at the point where it enters the gearbox. Using a hammer and a block of wood to protect the threads, tap (NOT WHACK) on the shaft trying to drive it toward the motor. If your mark disappears you have (temporarily) fixed the saw. Continue tapping until no more movement occurs. Re-mount the blade with all flanges and try to manually pull the blade away from the motor. If you feel movement, a retainer is crushed or broken. Time to go inside...
I cannot give you more advice for your saw as I have not worked on that model, but most saws are assembled much the same.
Hope this helps.
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
The Following User Says Thank You to mickey cassiba For This Useful Post:
Old 11-04-2011, 10:38 PM   #4
Rewards Points: 42
Thanks! I did figure it out, I think. The problem seems to have do something with the blade. I put in a new blade which is thinner. I put the old blade back in, which is burnt and bad, and it tightened up.
Regards
Old 11-04-2011, 10:41 PM   #5
Rewards Points: 42
Thanks! I did figure it out, I think. The problem seems to have do something with the blade. I put in a new blade which is thinner. I put the old blade back in, which is burnt and bad, and it tightened up. Either the problem is with the thickness of the blade where the flange won't catch and tighten up or maybe the blade is too smooth and the flange is not catching and thus tightening. I'll try roughing up the blade. It's a Diablo (I paid $20 for it at Home Depot).
Regards
The Following User Says Thank You to mrivney For This Useful Post:
oh'mike (11-05-2011)
Old 11-05-2011, 09:57 PM   #6
Rewards Points: 42
Hope this helps.
OK. I've tried roughing up the new blade at the center. There was a sticker. Plus it's painted. Didn't matter. Note, the new blade is 6 1/2" diameter and the old blade is 7 1/4" diameter.
I'll ask my neighbor tomorrow to see if he can figure it and I'll report back.
Old 11-14-2011, 01:09 PM   #7
Rewards Points: 42
My neighbor, Al, figured it out! The new blade is thinner, by some decimal figure (I don't remember what was the difference on the caliper readings of the two blades)! Thus, when tightening the screw onto the arbor, it stops just short of tightenting, thus spinning the shaft.
BTW, got the right size blade and it still happened. Went with another brand, which works. Will later grind down the bolt by a few mils.
Thanks for all your help.
oh'mike (11-14-2011)
Old 11-14-2011, 01:21 PM   #8
Household Handyman
Rewards Points: 1,408
So you found the problem before I could post the answer-good for you. YES--some of today's new blades, made oversea's I'm sure, are just thin enough that they will not tighten up in some older saws. I have had this experience. Fortunately when I found this problem with one of my older saws I was working as a machinist and altered the screw just enough to tighten up on the newer thinner blades. Also--you stated that you used a smaller diameter blade in you saw, not a good practice IMO.
Old 11-14-2011, 01:22 PM   #9
Rewards Points: 22
Before modifying the bolt, you might want to replace the cup that goes on the bolt, on the outside of the blade; could be that it is worn and/or flattened a bit after 30 years.
Old 11-14-2011, 01:24 PM   #10
Rewards Points: 42
Dexter,
OK. I'll check it out. The flanges may be a bit thinner. I think it's the new blades. They're thinner.
Regards, Mike
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 07:49 PM
Ceiling issue wooten General DIY Discussions 5 06-06-2011 08:20 PM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 09:19 AM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 02:34 PM
replacing vanity light...issue with outlet box? tarheelblue Electrical 5 01-28-2008 10:20 AM
