#1 |
siding brake
purchasing a new siding brake, should I buy the Tapco 14 or the Tapco 19?
The 19 is $100 more. |
#2 |
Mod
siding brake
The difference between the two is a 14” or 19” throat depth. I have a 14” and have used and abused if for years. It’s a very rare occasion when I need more than a 14” depth. When I do I just take the metal to a local sheet metal shop and let them bend it.
The 14” is a big enough awkward pig for 1 guy to move around. I know I wouldn’t want anything bigger. I remember and re-read you’re your last post about needing this for just one job. If you’re planning on selling this when you’re done be sure to get the 10’ break. You might find it much harder to sell the 8.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#3 |
siding brake
For one job, why not rent it?
Ron |
#4 |
Mod
siding brake
#5 |
siding brake
extra depth is usually not needed for most residential siding work
#6 |
siding brake
I had the smaller depth brake for many years. When I bought a new one, I bought the deeper throat. (don't google that). While you don't necessarily need it to bend typical pieces, it does come in handy when you are cutting pieces from a 24" piece of coil stock. Similar to ripping on a table saw. It many times will eliminate reinserting the wider piece back in the brake to cut off another say 7" strip. The smaller one will get you the same end result, for a $100, the choice is up to you.
Mike Hawkins
| The Following User Says Thank You to firehawkmph For This Useful Post: | Tom Struble (07-24-2010) |
| Display Modes | |
| Rot under vinyl siding | zackinma | Building & Construction | 1 | 12-28-2009 11:07 PM |
| New siding, paint exsisting siding, or powerwash?? | fixiechick | General Discussion | 5 | 01-23-2009 12:50 AM |
| Siding: Cement Vs. Cedar | Grumpy | Remodeling | 5 | 03-19-2005 02:07 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 1 | 03-19-2005 01:55 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 0 | 04-18-2004 04:35 PM |
