Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-24-2012, 03:10 PM   #1
side play
i have a Delta 28-243 bandsaw, the upper wheel appears to have side play when the saw is untighted. is this normal, is this an adjustment. thanks
Summit43 is offline   Reply With Quote
Old 06-24-2012, 05:07 PM   #2
side play
Open up the cover and grab the top and bottom of the wheel and try to move it. Look at the shaft and see if the shaft and wheel are moving at the same time.
Then grab it on the two sides and try that.
What your looking for is to see if it's worn bearings.
If the wheel can move from side to side and the shaft stays still then the bearing may need changing.
The shaft and wheel may wiggle a little but because it has to be able to move up and down in a track.
PaliBob (06-26-2012)
Old 06-24-2012, 06:38 PM   #3
side play
On at least some saws, the upper wheel is attached to a bracket, carriage, or whatever you want to call it, which in turn is mounted to the frame on a pivot, and there is a screw of other adjustment at the bottom of the bracket, which can be adjusted to keep the wheels on a common plane as the saw wears. If your saw is configured in some such manner, still check the pivot points, to make sure that nothing is worn, but you may otherwise be seeing normal movement. And, by the way, when you will not be using your saw for extended periods, it is a good practice to relieve the pressure on the blade a bit, in order to prevent flat spots on the wheel treads.
Old 06-25-2012, 11:05 AM   #4
side play
the top wheel is mounted to the sliding bracket. when all the tention is off the blade their may be slite movenent but when tighten their should be no movement . Look at the beiring and rock the wheel back and forth if no play is at beiring all is ok. I have the 28-245 and that is how mine is.
del schisler is offline   Reply With Quote
Bath tub is installed, but room to play with on right side. roasted Kitchen & Bath Remodeling 8 06-15-2012 01:27 AM
Need help picking a stainless side by side knotquiteawake Appliances 6 04-24-2012 12:38 PM
Now, Square D Combo AFCI Breaker Trips Opens w/No Load Side Connections QO120CAFI mysterylectric Electrical 8 11-02-2011 08:15 PM
Kenmore side by side. Freezer way too cold, Fridge is barely cold Steevehu Appliances 4 08-14-2011 11:32 AM
Backyard Play Area for Kids sippinjoes Landscaping & Lawn Care 8 06-30-2011 10:29 AM
