Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-17-2012, 01:55 PM   #1
shorty / low-clearance L-shaped allen wrenches
I am looking for a set of metric allen wrenches, the L-shaped variety, only they have to be "low-clearance" to work in really tight places; the short leg should be half the length it normally is, or even less if possible:
instead of
Do these exist? If so, what are they called? Thanks
diy888 is offline   Reply With Quote
Old 06-17-2012, 01:56 PM   #2
Actually, I just found it! "Stubby"
Old 06-17-2012, 10:01 PM   #3
why not cut off regular ones ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 06-17-2012, 10:59 PM   #4
In a little over my head
I just cut 'em off. But good luck with a hacksaw. Use a grinder and it goes pretty fast.
ratherbefishing is offline   Reply With Quote
Old 06-18-2012, 09:07 AM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
You can find them probably at harbor freight. Usually people just grind another set down for stuff like this.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 06-22-2012, 04:04 AM   #6
Tool Geek
PaliBob's Avatar
Originally Posted by diy888 View Post
......I just found it! "Stubby"
Here is one place to buy them.
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
gregzoll (06-22-2012)
Old 06-22-2012, 11:07 AM   #7
Household Handyman
One of the neatest tools I own: A set of "Chapman" allen type bits with ratcheting handle, these also come in metric and torx.
Old 06-22-2012, 12:10 PM   #8
Tool Geek
PaliBob's Avatar
Chapman Sets also come in:
Standard and Metric Allen Hex, Phillips,
Slotted, Torx, Bristol, Robertson Bits
All these bits in one Set
For just a set of Security Bits
these are pretty complete
& Stay Safe
.....Bob Lavery
Old 06-22-2012, 12:38 PM   #9
Tool Geek
PaliBob's Avatar
Originally Posted by ratherbefishing View Post
.......Use a grinder and it goes pretty fast.
Agreed, but an even cleaner way way is with a Dremel rotary tool.
with a EZ Lock Cut-Off Wheel
Any generation Dremel tool will work. Here is the Latest
I used that Dremel Cut-Off wheel in older model Dremel to cut through a Euro style round shape high security padlock (I won't say the name) in 40 seconds.
& Stay Safe
.....Bob Lavery
