-   Tools (http://www.diychatroom.com/f29/)
-   -   shorty / low-clearance L-shaped allen wrenches (http://www.diychatroom.com/f29/shorty-low-clearance-l-shaped-allen-wrenches-147340/)
diy888 06-17-2012 12:55 PM
I am looking for a set of metric allen wrenches, the L-shaped variety, only they have to be "low-clearance" to work in really tight places; the short leg should be half the length it normally is, or even less if possible:
instead of
Do these exist? If so, what are they called? Thanks
diy888 06-17-2012 12:56 PM
Actually, I just found it! "Stubby"
Fix'n it 06-17-2012 09:01 PM
why not cut off regular ones ?
ratherbefishing 06-17-2012 09:59 PM
I just cut 'em off. But good luck with a hacksaw. Use a grinder and it goes pretty fast.
gregzoll 06-18-2012 08:07 AM
You can find them probably at harbor freight. Usually people just grind another set down for stuff like this.
PaliBob 06-22-2012 03:04 AM
1 Attachment(s)
Originally Posted by diy888 (Post 945484)
......I just found it! "Stubby"
Here is one place to buy them.
Thurman 06-22-2012 10:07 AM
1 Attachment(s)
One of the neatest tools I own: A set of "Chapman" allen type bits with ratcheting handle, these also come in metric and torx.
PaliBob 06-22-2012 11:10 AM
Chapman Sets also come in:
Standard and Metric Allen Hex, Phillips,
Slotted, Torx, Bristol, Robertson Bits
All these bits in one Set
For just a set of Security Bits
these are pretty complete
PaliBob 06-22-2012 11:38 AM
1 Attachment(s)
Originally Posted by ratherbefishing (Post 945800)
.......Use a grinder and it goes pretty fast.
Agreed, but an even cleaner way way is with a Dremel rotary tool.
with a EZ Lock Cut-Off Wheel
Any generation Dremel tool will work. Here is the Latest
I used that Dremel Cut-Off wheel in older model Dremel to cut through a Euro style round shape high security padlock (I won't say the name) in 40 seconds.
