Shop Vac Suggestions - Tools - DIY Chatroom Home Improvement Forum
Old 08-18-2013, 09:37 PM   #1
Rewards Points: 208
do you have shop vac suggestions? i'm leaning towards this ridgid from home depot. only negative: the hose attachments don't clip-on...they just slide on, which i don't like because the attachments never stay on. i've never seen a shop vac with clip-on hose attachments, though.
http://www.homedepot.com/p/RIDGID-14...6#.UhGDQz_fJGg
Scully is offline   Reply With Quote
Old 08-18-2013, 09:52 PM   #2
Still Decompressing
Rewards Points: 273
I recently purchased the smaller Rigid (4g, 5hp) Vac from HD. It was the best combinatio I could find of a smaller compact unit with decent power.
It does have the clip on hose accesorries.
So far, so good.
caveeagle is offline   Reply With Quote
Old 08-18-2013, 10:49 PM   #3
Gymschu's Avatar
Rewards Points: 834
Love my Ridgid vacuum. Used to buy Shop Vacs but was only getting a year or two service out of them. The Ridgid is going strong for 3 years now......built much better than the throw away Shop Vacs.
Gymschu is online now   Reply With Quote
Old 08-20-2013, 11:50 AM   #4
I've always been impartial towards Rigid. It's a good brand.
TreverS is offline   Reply With Quote
Old 08-20-2013, 02:17 PM   #5
Too Short? Cut it Again!
Look in the tools section of this forum. There was a recent discussion about shop vacs preferences.
As I mentioned, ones that will accomodate bags was a biggy for me.
Old 08-20-2013, 10:58 PM   #6
Rewards Points: 208
i will look. i like rigid, and the reviews are solid, but the slide on hose attachments kind of is annoying.
Old 08-21-2013, 08:50 PM   #7
Rewards Points: 952
I have a big rigid and it has the clip on hose and slide on attachments. I have a reducer and I use a central vac hose in my shop with some attachments.
It would be super fine to figure out how to rig up a central vac inlet which I can plug my central vac hose into and use the switch to turn the rigid on and off with.
How would one do dat?
cleveman is offline   Reply With Quote
Old 08-21-2013, 11:02 PM   #8
I have Rube-Goldberged pvc non-glued sllip plumbing fittings to adapt the exhaust ports of all my sanders to exhaust tubing. That tubing slides into a pvc fitting/adaptor on the shop vac hose. A little duct/duck tape so things do not slide off and it works out great.
Not sure how you would rig a wall switch to turn on the shop vac. I guess you could run a switch to an outlet, leave the shop vac switch in the on position, and plug it in to the switch controlled outlet?
Old 09-05-2013, 12:01 AM   #9
Rewards Points: 263
I've got the small 4 gal version as well as the separate car cleaning kit. (Which has a longer hose and couple of specialty brushes.)
They hoses do clip on, but can be a pain in the butt to get on or off sometimes. As well... I'm not sure what the diameter is of the hose, but it's not standard for some other dust collection systems. (Like for the output of my router table dust port and some other items.) This is solvable enough with reducers and other tubes and - if necessary - of course there's duct tape. But maybe a couple more $$ for these parts if needed.
Oh, you probably know this, but I've found the key to getting good suction is to clean the filter when needed. Which is annoying, but... one of those things.
Scottg is offline   Reply With Quote
Old 09-07-2013, 06:42 PM   #10
Rewards Points: 107
Just bought the rigid 16 gal with the detachable blower. I love it! I bought the noise muffler, but will return it as I don't think it really reduces the noise any
Ranger1227 is offline   Reply With Quote
Wood shop 100 amp sub panel tinybear Electrical 6 02-08-2013 10:31 PM
Wiring shop need advice stqevo Electrical 14 09-03-2009 12:18 PM
Sizing wire/breaker to new shop. Roy Rowlett Electrical 8 04-22-2009 12:29 PM
sub panel in house from shop rustic Electrical 1 01-25-2009 11:58 AM
Shop Vac handy man88 Appliances 2 10-07-2008 08:48 PM
