Shop Vac: How Does It Work? - Tools - DIY Chatroom Home Improvement Forum
Old 10-27-2013, 04:36 PM   #1
Rewards Points: 208
Shop Vac: How Does it Work?
when i put a filter bag into my ridgid shop vac, how does the suction get through the hose when the bag is in between? i mean...the center suction unit is not connected to the bag, so i don't get how the suction comes through the hose?
Uploaded with ImageShack.us
Scully is offline   Reply With Quote
Old 10-27-2013, 04:45 PM   #2
Rewards Points: 13,300
It's magic.
http://www.ehow.com/info_12076432_shop-vacuum-work.html
Startingover (10-27-2013)
Old 10-30-2013, 10:32 PM   #3
Rewards Points: 208
Originally Posted by joecaption View Post
the link doesn't answer my question.
Old 10-31-2013, 01:45 AM   #4
jschaben
Rewards Points: 502
I can't get technical because... well, I can't. It's just that the bag is porous enough to allow air flow. That's why your suction falls off as the bag fills. Sorry, best I can do.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 10-31-2013, 02:28 PM   #5
Oso954's Avatar
Rewards Points: 768
The filter bag, is just a bag shaped filter. It stops dust and lightweight debris from entering the fan/motor area, while letting air flow thru it.
The lid of the shop vac makes an air tight seal on the bucket. The motor/fan pulls air out of the bucket, creating a low pressure area (partial vacuum) in the bucket. Outside air rushes up the hose attempting to fill the low pressure in the bucket. (The fan is sized to eject more air than the hose/inlet will let in.)
The air inrush, pushes (not pulls) dirt and debris up the hose. The dirt/debris drops to the bottom of the bucket.
If you had a solid connection between the hose inlet and the fan area, the dirt/debris would run thru the fan, and eject out the exhaust outlet.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Scully (10-31-2013)
Old 10-31-2013, 10:02 PM   #6
Rewards Points: 208
thanks for the explanation, Oso954. if the bag acts as a filter for the drum so dirt doesn't fly out of exhaust, then the hepa filter on the motor/fan prevents dirt from flying out of motor/fan?
Old 10-31-2013, 10:11 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,146
What really happens is that when you turn on the shop vac, the motor pushes air out of the vacuum. When this happens the pressure inside drops. Because the pressure outside the hose is greater, atmospheric pressure pushes air down the hole...this pressurizes the bag..and the motor again pushes it out of the vacuum.
Because the holes in that bag are smaller than the dirt, but bigger than air molecules, air goes through, but not the dirt.
ddawg16 is online now   Reply With Quote
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 04:19 PM
Running wires in a shop seanbarr Electrical 23 02-22-2012 11:31 PM
New work vs Old work Tetranitrate Electrical 3 07-12-2011 09:19 AM
