Sears Drill Press Makes Flash - Tools - DIY Chatroom Home Improvement Forum
Old 12-25-2010, 11:34 AM   #1
Question
Sears Drill Press makes flash
I recently bought an older Sears 3/4 hp drill press. Sometimes when you turn it on the motor makes a small flash inside the motor right under the wireing plate.
After matching this several time I found out this was coming from the "centrifugal start switch". I took apart the motor and removed a hornets nest - -sanded the contacts- - -and reassembled the motor. The thing still makes the flash. However, it runs great. Where can I buy a new switch? Can the old switch be fixed? Is it OK to run the motor like it is? I appreciate any help.
sclaggett is offline   Reply With Quote
Old 12-26-2010, 10:44 AM   #2
Rewards Points: 468
i wouldn't worry about that. that is the start run plate. You mite go to a motor shop. I belive they may have a paste that can go on the contat's to cut down the ark. When you sand down the contact's that is not good. their is a coating that should be on them. Sanding now they are contacting like metal to metal . I belive the contact's are silver coated.Now that is gone so the flash is what you will get now. I would take the motor model number down to the repair shop they should be able to get a new one for you ??
del schisler is online now   Reply With Quote
Old 12-28-2010, 02:12 PM   #3
Drywall contractor
Rewards Points: 1,068
Try sears.com/parts. They may carry parts for your drill press if it's not too terribly old....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drill: What type to buy? Hurriken Tools 13 09-07-2010 05:00 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
Determining correct drill key MRTIGRE General DIY Discussions 3 06-04-2009 02:58 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 02:46 AM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 10:12 AM
