SDS Drill To Mix Thinset - Tools - DIY Chatroom Home Improvement Forum
Old 01-21-2014, 11:04 AM   #1
Smile
SDS drill to mix thinset
I'm new to this forum and there seems to be a ton of great information on this site. I'm a home DIY'er and looking at finishing some floor tile and need to punch holes on cement slab for other project.
I have access to a buy a second hand bosch bulldog sds drill (neighbor upgraded and wants to sell for $75)and wondering if I add the 3 jaw chuck how it would work on mixing thinset? I know it could handle punching holes but not sure on high torque thinset jobs? Or just go to HD and put $100 on a hammer drill?
Surfer4fun is offline   Reply With Quote
Old 01-21-2014, 05:55 PM   #2
DIY staff
Rewards Points: 7,174
I never tried an sds drill as a mixer---
I used a 1/2" Milwaukee Hole Shooter for years---that works---you need a slow speed,High torque drill---
Last year I bought a mud mixer---I like that,but it is only good for mixing mud and would be a silly purchase for a one time job.
Old 01-21-2014, 08:34 PM   #3
Rewards Points: 392
Pretty sure that the Bulldog can be switched between hammer and regular drilling, so if you got a Jacobs chuck adaptor (which I believe are available) it should have no problem mixing thinset.
rustyjames is offline   Reply With Quote
Old 01-22-2014, 07:58 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,338
as mike stated a high torque low speed drill is best suited for this.. ive seen several guys try to use regular drills for this sort of thing and they only burn out the motor on the drills as their not designed for mixing something thats very thick and heavy
woodworkbykirk is offline   Reply With Quote
Old 01-22-2014, 01:14 PM   #5
Rewards Points: 121
I have been using one of these for years with good results:
http://www.harborfreight.com/1-2-hal...ill-93632.html
jrepp44 is offline   Reply With Quote
Old 01-23-2014, 09:48 AM   #6
Professional
TotalHomeworx's Avatar
That drill would be good for other things as well as that so it may be a good purchase otherwise I would just rent one.
TotalHomeworx is offline   Reply With Quote
Old 01-24-2014, 11:30 AM   #7
Rewards Points: 34
None of the Bulldogs have a slow speed (low RPM) setting as far as I know. They have variable speed trigger with max speed of around 1,200-1,500 RPM. Not good for mixing thinset at all. If you try to feather the trigger to mix slowly the motor will heat-up & burn-out. If you try to mix at 1,200 RPM, well, all he## will break out.
If you really want a dual purpose drill, a quality, corded, high amp, 2-speed, 1/2" hammer drill can do OK mixing some thinset IF you're carefull not to let it overheat. They are fine for a DIY'er drilling small diameter holes (~3/8") in masonry and OK for holes up to around 3/4" max.
The Bulldogs are faster & better for masonry drilling & good for a bit of chipping, but the bits are expensive too.
midwestcoast is offline   Reply With Quote
Old 01-24-2014, 02:56 PM   #8
Rewards Points: 392
Midwest brings up a good point about the speed. You'd be better off buying something more suited for the task.
Tags
bosch , drill , hammer drill , sds drill , thinset
drill 2.5" hole through 10" concrete hole diy001 Remodeling 7 01-17-2016 05:50 PM
What is best portable way to Drill holes through 1/2" steel? peakcelln Building & Construction 29 10-11-2012 05:25 PM
Which would be the better drill to buy? Syii Gardan Tools 6 07-31-2011 11:38 AM
Looking to buy new Drill Track Tools 30 05-04-2011 03:55 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 01:46 AM
