Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-20-2012, 05:02 PM   #16
Screws
My point was that ALL screws are self tapping, because I've never believed that a machine screw is a true screw. Couple that with the fact that self drilling screws are commonly referred to as self tapping screws, and now there's opportunity for nomenclature debate.
jlmran is offline   Reply With Quote
Old 02-20-2012, 05:07 PM   #17
bbo
Screws
and now I know where the phrase "screw that" came from.
isn't 10-24 a measure of the threads, irrelevant of whether its a screw or bolt?
edit 10 being a measure of diameter (thickness) and 24 being number of threads per unit of measure.
bbo is offline   Reply With Quote
Old 02-20-2012, 09:49 PM   #18
Screws
Your edit is correct....but wood and sheet metal screws generally are described only by diameter and length, not tpi....generally
My answers are based on years of experience doing things wrong ....and intended to keep you from doing the same....
Missouri Bound is online now   Reply With Quote
are deck screws enough to stop a kick in? Tonglebeak Carpentry 18 12-10-2011 09:19 PM
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 25 12-06-2011 07:04 PM
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 08:34 PM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 09:56 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
