Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-10-2012, 09:53 AM   #1
Screws
Hi, when looking at screws to buy in my local store the majority are wood ones, I am planning to drill into house brick and then use plug along with the screw. So my question is can I use a wood screw for this purpose? Thanks
Homervanderjazz is offline   Reply With Quote
Old 02-10-2012, 10:05 AM   #2
Screws
No, a wood screw is tapered.
What is it your planning on mounting with these screws?
Cheap not going to work very well plastic inserts use sheetmetal screws.
Lead anchors use lag screws.
(there called inserts not plugs)
Old 02-10-2012, 11:10 AM   #3
Screws
Hi I am just putting up Shelves, when I go onto screwfix.com and look at screw section the masonry screws seem to be ones that are to be used without plugs. Which screws would suitable on this site to be used with plugs? Thanks
Old 02-11-2012, 04:51 AM   #4
Tool Geek
PaliBob's Avatar
Screws
Originally Posted by Homervanderjazz View Post
.....am just putting up Shelves.....
Homer, This should help with Screw Anchors:
http://en.wikipedia.org/wiki/Screw_anchor
For installing shelves on brick walls:
http://www.home-shelving-guide.com/i...g-shelves.html
Hope this helps. Use sheet metal screws with plastic anchors
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-16-2012, 08:27 PM   #5
Screws
Is there any reason why you should use a plug/screw in brick instead of a masonry screw by itself? Or is it a matter of what is strong enough for the application?
I usually use masonry screws when I need to secure something to my block foundation (like a fire extinguisher hangar - I had them handy, although it seemed like overkill - those blue screws have some bite)
KatHelms is offline   Reply With Quote
Old 02-16-2012, 11:24 PM   #6
Screws
It depends more on the application than any other factor....and how it looks when finished in some circumstances. And yes, the Tapcons hold very well.
My answers are based on years of experience doing things wrong ....and intended to keep you from doing the same....
Missouri Bound is online now   Reply With Quote
Old 02-17-2012, 05:44 AM   #7
Screws
thanks for all the replies folks
Old 02-17-2012, 03:03 PM   #8
Tool Geek
PaliBob's Avatar
Screws
.....those blue screws have some bite)
Those blue screws most commonly called Tapcon® screws are self Tapping screws that are most commonly used in concrete, hence the name:Tapcon. The Tapcons are awesome in Concrete but I would not use them in brick. Brick is after all just a block of clay baked in a kiln. Concrete bricks would be the exception but they are not as common.
Besides the unknown strength of a brick, especially older construction bricks, a drawback of using a Tapcon in brick is that if it is removed even temporarily they cannot be reinstalled in the same hole because now the original sized hole has been tapped out by the first installation.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-19-2012, 09:38 PM   #9
Screws
All the Tapcons I've bought came with a masonry bit. Are they really self-tapping?
jlmran is offline   Reply With Quote
Old 02-19-2012, 09:48 PM   #10
Screws
Yes, they are self-tapping. Self-DRILLING screws do not require a pilot hole, but I haven't seen those for concrete......at least not yet.
Oops..I said that backward. Self tapping screws have their own bit at the tip...they do not reuire a hole
Old 02-19-2012, 09:54 PM   #11
Screws
So all screws are self-tapping?
Is a 10-24 a screw or a bolt?
Old 02-19-2012, 10:03 PM   #12
Screws
Now that's a matter of semantics.
Old 02-19-2012, 11:15 PM   #13
Screws
Which question?
Old 02-19-2012, 11:26 PM   #14
Screws
Generally, and from my personal experience, 1/4" or larger is a bolt, less than 1/4" is referred to as a machine screw. But there are lag bolts smaller than 1/4" and dowel screws larger than 1/4".....like I said, semantics The most common reference will be used and acknowledged.
Old 02-20-2012, 01:34 PM   #15
Tool Geek
PaliBob's Avatar
Screws
How did Tapcon get its name?
An anchor that TAPs its own threads/grooves into CONcrete.”
above quote from the Tapcon website http://www.tapcon.com/history.asp
The hole diameter is smaller than the screw diameter, e.g.a ¼” screw is installed in a 3/16” hole. The screw jambs itself into the walls of the hole by self-tapping the hole to a larger diameter. If the Tapcon screw is removed then re-installed in good quality concrete it wil probably be ok, at least for the first time. Old poorer quality concrete or mortar is not going to hold as good, same for brick.
Disclaimer
& Stay Safe
.....Bob Lavery
are deck screws enough to stop a kick in? Tonglebeak Carpentry 18 12-10-2011 09:19 PM
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 25 12-06-2011 07:04 PM
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 08:34 PM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 09:56 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
