Sawsall Blades - Tools - DIY Chatroom Home Improvement Forum
Old 02-12-2014, 07:16 PM   #1
Rewards Points: 13,750
Sawsall Blades
I was in Costco today. They had a blister pack package of 20 Craftsman branded bimetal sawsall blades and a plastic case for about $20.00 plus tax.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Gymschu (02-12-2014), PaliBob (02-13-2014)
Old 02-12-2014, 07:19 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 684
Can't beat $1 a blade- no matter what brand. Are Craftsman blades good?
Old 02-12-2014, 07:50 PM   #3
No clue but at $1.00 a blade I'm going to take a chance.
My local hardware wanted $12.00 for one 12" blade.
HD wanted about $12.00 for 5.
I see Costco now has several Craftsman branded products in stock.
Old 02-12-2014, 07:54 PM   #4
firehawkmph's Avatar
Rewards Points: 1,884
I have had the best luck with Lennox blades over the years. The longer ones will bend 90 degrees without breaking and last along time. When they finally do get a bit dull, I use em for cutting plaster until the teeth wear off.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-12-2014, 08:01 PM   #5
DIY staff
Rewards Points: 7,174
Good tip,Joe---I dropped a bundle yesterday on two packs of Milwaukee blades---Like Firehawk--I find Milwaukee and Lennox to be the cheapest in the long run----
But at a buck a blade? I'll give them a shot---
Old 02-12-2014, 08:10 PM   #6
I also buy Lenox most of the time.
I even lost a lottery one time on how long it took to cut a unibody car in half with a Lenox blade.
Less then 5 min. was the correct answer.
Old 02-12-2014, 08:22 PM   #7
I'm a Lennox fan as well, although my local Menards has some cheapos that I may try. I'm sure I'll regret it, but they have a brand called MaxBuilt or something that they are almost giving away compared to some of the higher priced brands.
For only $20, you will almost certainly get your money out of them.
jponto07 is offline   Reply With Quote
Old 02-13-2014, 07:39 AM   #8
MarginallyQualified
Rewards Points: 2,464
I'm done with Sears and Craftsman.
Free? OK I'll use 'em but I won't pay a penny.
As for blades and bits... Lenox and Bosch.
Old 02-13-2014, 03:28 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
joe.. buy blades through a wholesaler. we buy teh milwaukee axe 12" blades from a wholesaler in packs of 100.. it works out to $4 a blade after tax. through big box stores there $11 each
woodworkbykirk is offline   Reply With Quote
Use Rockwell blades on Dremel Multimax miamicuse Tools 0 03-09-2013 11:27 AM
Ridgid Saw blades kevsprojects Tools 12 03-17-2012 07:16 AM
Need Help Replacing Spiral Blades on Snow Thrower cynergyou General DIY Discussions 3 01-22-2011 08:53 AM
Sears 536.884351 auger blades are discontinued, no replacement MichaelLit General DIY Discussions 2 07-08-2009 06:43 AM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 04:50 AM
