Saw Blade For Aluminum - Tools - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 05:17 AM   #1
saw blade for aluminum
I am finally ready to start a project except for a saw blade to cut aluminum. I have a 12" miter saw with 1" or 5/8" arbor (DWS780.) I do not know much about cutting metals. I've always used a cutting wheel on a grinder before.
Here are two blades that jumped out at me online:
Freud D1296N Diablo 12" 96T TCG $55.92
Irwin 1807386 Marples laser cut 12" 100T TCG $112.54 + $6 shipping
Can these TCG toothed-blades also be used for woodworking or rough cross-cuts? If so I could just leave it in the saw all the time. Otherwise, I might buy the cheaper one, because I won't be cutting aluminum too often.
Thanks!
jeffsw6 is offline   Reply With Quote
Old 12-11-2012, 05:26 AM   #2
Aluminum is very sticky, and rather than dulling the blade, you will see bits of aluminum welded to the teeth. A carbide tipped saw specifically made for cutting aluminum is best. You can buy a stick wax lubricant for grinding aluminum, and Crisco works, too. For sawing and drilling, WD-40 or kerosene works pretty well at preventing chip welding. I've cut plenty of steel with a sawzall; aluminum is much softer/easier, if you can prevent chip welding.
Tindra is offline   Reply With Quote
Old 12-11-2012, 05:48 AM   #3
I thought these TCG blades were intended for cutting aluminum. If not, could you suggest a specific blade?
Old 12-11-2012, 06:15 AM   #4
I'm suggest a specific blade Saw Blades, toothed blade, abrasive blades
Old 12-11-2012, 06:43 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Thanks!
Ayuh,.... Without takin' the time to google up those blades,...
I donno if they'll work well on wood, or not...
However,...
I cut, 'n weld aluminum on a fairly regular basis, 'n use standard wood workin' blades, All the time, though the finer tooth count blades, do work better...
Carbide tipped blades are a Huge plus,...though not absolutely necessary...
as noted by Tindra, aluminum is rather sticky in a way,...
It has a tendency to melt at saw blade temps, 'n glue itself to the blade tips, causin' it to stop cuttin', 'n load up even worse...
I've found 2 ways to deal with this,...
1 bein' using beeswax to well lube the cuttin' blades,...
Startin' cold, the wax shreds, but as the blade warms, the wax coats it nicely, 'n helps alot to stop the hangin' of the metal...
WD-40, or other spray lubes may help, donno, as I've fallen in love with the beeswax thing..
I just keep a small block of it handy near by, 'n use it to rub the blade, Often...
The other way, which works out Great this time of year, is keepin' the metal Cold,...
Aluminum passes heat, Really quickly, so holdin' a chunk of ice, or a snowball on the aluminum sucks the heat out of it, 'n allows long cuts, quickly...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
woodworkbykirk (12-11-2012)
Old 12-11-2012, 07:13 AM   #6
47_47's Avatar
Rewards Points: 58
Thanks!
As others said use a wax stick to dissipate the heat.
What size aluminum are you cutting? For thin aluminum (up to 1/4" thick), use a carbide tipped 12" blade with a minimum of 80 teeth with a zero to negative hook.
This blade could be used with finish trim, 1x material..., but will not work well on rough cutting thicker material (2x). Plan on getting two blades.
47_47 is offline   Reply With Quote
Old 12-11-2012, 08:00 AM   #7
I think the reason the TCG teeth are recommended by Dewalt is because they should cause less Al to stick onto the blade. I didn't know what TCG was so I looked it up, and it seems like this is probably the idea behind it.
The Al is 1/8" thickness angle pieces, both sides are 1 1/2" long.
I already have regular blades for cutting wood. I just thought I might save some time (blade changes) if the blade that works well for Al will also do some wood-cutting tasks. Hopefully I will get all the aluminum cuts right on the first try though...!
Old 12-11-2012, 09:30 AM   #8
47_47's Avatar
Rewards Points: 58
Small cut-offs may fly. If you are cutting any angle, clamp the piece to the saw, it will creep when cutting.
Old 12-11-2012, 02:57 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
regular wood blades with a hight tooth count will work.. but a non ferrous metal blade works even better. the only real difference ive noticed is the angle of the hook on the tooth of the blade
woodworkbykirk is offline   Reply With Quote
Circular Saw - Blade Plug Problem ejseidman Tools 7 10-01-2012 01:04 PM
How many Tooth Saw Blade for Trim? HandyFrank Carpentry 11 12-28-2011 07:11 PM
Best Tools for Drywall Removal? neo95gt Drywall & Plaster 59 12-27-2011 12:44 PM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 04:55 AM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 04:26 PM
