-   Tools (http://www.diychatroom.com/f29/)
-   -   Ryobi BE318-2 Repair Help (http://www.diychatroom.com/f29/ryobi-be318-2-repair-help-150843/)
xepherys 07-19-2012 03:17 PM
Hello,
I'm using a Roybi BE318-2 belt sander to sand down some wood floors in a small room. Recently, the sand paper belt caught on something and tore and a piece of the paper is lodged behind the drive wheel. I'm trying to disassemble the sander to get at the paper and remove it (and check the drive belt - there was a slight rubber odor), however it's not as easy as most tools I've repaired. (well, it probably is, really).
I've removed the 8 housing screws on the right side of the sander, but the housing will not come apart. I checked for a 9th screw under the branding sticker, but there was nothing there. I have an assembly diagram for the -2 model and it seems that it should only be the 8 screws holding it together. Any thoughts on what I'm missing? This is really throwing a wrench (or some sand paper) into my progress.
Thanks!
PaliBob 07-19-2012 03:28 PM
This Ryobi Repair Sheet might help
(four sheets)
Let us know how it gets fixed.
xepherys 07-19-2012 03:42 PM
Hey Bob,
Thank you, but that's the sheet I've been looking at. I removed the 8 screws that are listed as parts 31 and 32. I suppose, looking at it again, that I'll have to remove everything from the left side of the housing as well.
