Ryobi Battery Stuck... - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 12-07-2010, 06:57 PM   #16
Rewards Points: 150
Originally Posted by Sparky8370
Walk outside and wait for a big strong man to walk by. Ask him to pull the battery out for you.
She probaly will let you keep walking lol
ianc435 is offline   Reply With Quote
Old 10-24-2016, 04:05 AM   #17
Rewards Points: 4
Re: Ryobi battery stuck in the ...
Another solution to a stuck battery ... in my case, stuck in a blower:
Try loosening the screws that hold the apparatus together enough to allow you to withdraw the battery! Loosen them ... you probably do not need to remove them. It may be only necessary to loosen the screws closest the battery ... if loosening the ones closest doesn't work, loosen the ones next furthest out.
As suggested in previous posts by others, lubricate the battery with "Vaseline" where it makes contact with the apparatus housing.
Good luck!
Peter
pbills is offline   Reply With Quote
The Following User Says Thank You to pbills For This Useful Post:
BayouRunner (10-24-2016)
Old 10-24-2016, 06:18 AM   #18
Rewards Points: 4
Re: Ryobi battery stuck...
Try loosening the screws - that hold the apparatus together - enough to allow you to withdraw the battery! Loosen ... you probably do not need to remove them. It may be only necessary to loosen the screws closest the battery ... if loosening the ones closest doesn't work, loosen the ones next furthest out.
Good luck!
Peter
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 05:40 PM
fix dead ryobi battery smokeyjo Tools 10 02-04-2011 04:05 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 05:34 PM
Ryobi 12v battery system JElson Tools 3 10-11-2008 09:50 PM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 09:12 AM
