Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-23-2012, 05:12 PM   #1
Ryobi battery getting old/weak?
People,
Have a ryobi drill with one batery , 18v (see picture here):
http://www.ebay.com/itm/Ryobi-P100-1...item2326696b2c
Its maybe 3-4 years old. How long do they last? Mine now, after charging, is only good for about 5 minutes of drilling small drill bit holes. Is it time to buy new as shown in the ad on ebay? Or, buy a whole new drill/battery?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 12-23-2012, 07:31 PM   #2
Yeah, sounds like you are ready for a new battery. 3 or 4 years of use is not bad for any NiCad battery.
Unless you have some reason why you want a new drill, or you want to change to one that has battery compatibility with other cordless tools you own, then "if it ain't broke, don't fix it." Just keep buying new batteries every few years until you find some reason to upgrade your drill.
If you buy a battery from eBay make sure you test it as soon as you get it.
In my profession, we deal with uninterruptable power supplies (UPS) that have very large, expensive arrays of batteries. Buying a used UPS is a pretty normal thing but you have to be a LOT more careful about buying used batteries. People will rip you off.
I'm sure the same is true with consumer rechargeable batteries. Buyer beware.
jeffsw6 is offline   Reply With Quote
The Following User Says Thank You to jeffsw6 For This Useful Post:
noquacks (12-25-2012)
Old 12-24-2012, 12:23 PM   #3
Just go to Home Depot and buy the two pack.
http://www.homedepot.com/webapp/cata...gry=Search+All
If the batterys bad the charger should of had a blinking light.
Old 12-24-2012, 12:33 PM   #4
Super Moderator
You are at the end of it's life---$59 for two batteries at the Depot----or look for a special for about $100 that includes a tool you want.
I just picked up an impact gun and a drill--charger and two batteries for less than $100---
Old 12-25-2012, 09:33 AM   #5
Really?? Man, I didnt know! When I put in in to the charger, I dont get a blinking light! So, does that mean the battery's still "good"? What color is that blinking light? (just thought- I have the owners manual saved. Should maybe puull it out and study it....)
Old 12-25-2012, 09:44 AM   #6
I have two differant style Ryobi chargers, both have red and green lights.
Red for charging, green for fully charged. When the battery goes bad it blinks from red to green.
A few things that can give you a faulse reading is trying to chage a hot battery. If you using it and it goes dead your suppost to let it sit a few mon. to cool off before charging. If the charger is sitting in the sun while it's charging it will since heat and not charge the battery.
The contacts get dirty on the charger and the battery, I just use a pencil eraser to clean them off.
But batterys that old most likely are shot.
Old 12-25-2012, 10:52 AM   #7
I get it now, Joe..
Old 12-25-2012, 12:50 PM   #8
JOATMON
ddawg16's Avatar
I have the same batteries.....I get 4-6 years of use......depending on what I'm doing.
Leaving the battery on the charger for extended periods is not good for it....
If you plan on useing more Ryobi tools....go buy the tool of your liking with the Li battery.....those batteries work in your exting drill
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
The Following User Says Thank You to ddawg16 For This Useful Post:
noquacks (12-26-2012)
Ryobi battery powered sander opinion joshgfeller Tools 3 04-30-2012 04:49 PM
fix dead ryobi battery smokeyjo Tools 10 02-04-2011 05:05 PM
Ryobi battery stuck... EmmyS Tools 15 12-07-2010 07:57 PM
Ryobi 12v battery system JElson Tools 3 10-11-2008 10:50 PM
