Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 08-29-2011, 10:23 AM   #1
Ryobi 18v NiCd drill broken?
I was working on my new porch and i had my drill resting on a ledge. Then I knocked it off, first it fell four feet and hit the edge of the porch then another 4 feet to the ground where it rolled across gravel for a good distance. It survived yet now the variable speed does not work it is only off or full. What can I do to fix this.
sheafromme is offline   Reply With Quote
Old 08-29-2011, 11:00 PM   #2
Persona Non Grata
VIPlumber's Avatar
You probably dislodged the switch. You'll need to take it apart and adjust/reset the switch using a precision screwdriver set (a.k.a. - watch screwdrivers). It'll probably set you back about $10-20.
VIPlumber is offline   Reply With Quote
Old 08-30-2011, 07:48 AM   #3
I have to tools to do this so how should I go at it?
Old 08-30-2011, 02:02 PM   #4
Persona Non Grata
VIPlumber's Avatar
Take it apart and have at it. I'm not certain I understand your question.
Old 08-30-2011, 08:05 PM   #5
I mean how can i fix the variable speed
Old 09-01-2011, 09:56 AM   #6
Persona Non Grata
VIPlumber's Avatar
Hi Shea,
Here's what a quick Google search turned up, http://www.ifixit.com/Guide/Repairin...-Switch/2683/1
It's for a Ridgid drill, not the Ryobi you have, but the principles are the same.
Good luck.
Old 09-05-2011, 02:49 PM   #7
Hi Shea,
Good luck.
What i mean is that whenever i touch the trigger it is automatically on full speed whether it is on gear 1 or 2. there is no variability in the speed.
Old 09-05-2011, 11:43 PM   #8
Not a Noob or Boob
The trigger sounds busted. There is a spring that puts resistance on the trigger, sounds like the spring is off or broken. Open it and investigate. You may have to replace the switch. The only other option is to purchase a new drill.
Rob1975 is offline   Reply With Quote
Tags
ryobi drill speed
How can I disassemble my Ryobi drill? petar Tools 10 08-02-2011 06:36 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
Is my new hammer drill broken? darsunt Tools 13 09-16-2009 10:53 PM
Help with broken drill serill Tools 2 09-08-2008 12:14 AM
Broken Drill Bit Freelancer General Discussion 15 03-29-2007 05:01 PM
