Rusting Hammer - Tools - DIY Chatroom Home Improvement Forum
Old 11-16-2011, 07:17 PM   #1
Rusting Hammer
I have recently bought a new hammer and I have been leaving my old hammer in the toolbox in my car and it has been rusting .
Can anyone explain this?
Basketball1234 is offline   Reply With Quote
Old 11-16-2011, 07:24 PM   #2
DIY staff
Rewards Points: 7,174
It's been crying because you bought a new one and then locked in the dark cold trunk.
Bring it in--assure it that you still love it --clean it up and wax it---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
mickey cassiba (11-16-2011), VIPlumber (11-16-2011)
Old 11-16-2011, 09:07 PM   #3
Rewards Points: 148
You didn't forget to close the trunk before going through the car wash, AGAIN, did you?
Old 11-16-2011, 10:08 PM   #4
Rewards Points: 502
The a pair of Iron molecules form bonds with 3 Oxygen molecules
forresth is offline   Reply With Quote
Old 11-16-2011, 10:34 PM   #5
In a little over my head
Rewards Points: 706
My first thought was "claw or ball peen?" Then I saw who the OP was.
So, what'ya get?
ratherbefishing is offline   Reply With Quote
Old 12-01-2011, 08:38 AM   #6
Rewards Points: 256
I think the question wasn't rhetorical, so I'll give a real answer.
Water is in the air, that can cause things to rust. Try a Rust preventative. There are a lot of measures people take. The most common might be a coat of paste wax.
I met a guy that had a bucket of sand/engine oil mix?? He dunked his tools in that before returning them to their pegs in the shed.
Also, no need to trash a hammer for rust. Clean it off with a wire brush (wire wheel in an angle grinder or bench grinder works great) , then wax it.
michaelcherr is offline   Reply With Quote
Old 12-01-2011, 09:14 AM   #7
Rewards Points: 484
Don't know all about it. But here is what you can do that prevent it from rusting. Get some RUST-OFF AND T-9 the rust off will take all the rust off and make it look like new. now use the t-9 and you will not have rust any more. I use this in my work shop and use the t-9 on all iron top's and never no rust. i line in central florida. You can get this at sear's they stock it now. here is a link as to what you are looking for. This stuff was mfd. by boeing air craft for their use but it was so good that they sell it on the open market. http://www.mysears.com/Boeshield-T-9...leaner-reviews
del schisler is online now   Reply With Quote
Old 12-01-2011, 12:03 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 778
The hammer is condensating, it is thick steel and will hold heat for a good while. The trunk will heat up pretty good and the hammer will stay warm even when the trunk cools off, there you have heat and cool so it will produce condensation and rust the hammer. On the wax thing, don't get the wax on the face or it can glance when driving a nail and don't get it on the handle or you could sling that thing. OK I'm through now, next.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-01-2011, 12:57 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Rusty hammers are used for driving rusty nails.
XXX
The Following 4 Users Say Thank You to Bud Cline For This Useful Post:
BigJim (12-01-2011), del schisler (12-02-2011), TurboDIYer (01-04-2012), woodworkbykirk (12-11-2011)
Old 12-11-2011, 07:49 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
its nothing more than the dampness in the air condensating on the cold metal of the hammer. either a wire brush attachment in a drill or some sand paper can clean it up in no time
not a big deal as its only surface rust
woodworkbykirk is online now   Reply With Quote
Old 12-12-2011, 11:25 PM   #11
Kinda make one wonder what the rest of the tools in that toolbox look like.
Evstarr is offline   Reply With Quote
Old 12-13-2011, 08:13 PM   #12
the only tools i really worry about rusting are cutting tools such as hand planes and chisels.. rust causes the edges to dull so i try to keep such tools inside where the dampness doesnt get to them causing them to rust
Old 12-14-2011, 08:07 PM   #13
Rewards Points: 5,336
Yes I can.
Ron
B. Franklin 1759
Old 01-02-2012, 04:27 PM   #14
Chris
Give these a try. Being around water all day I have these stuck on all my boxes and they seem to be helping.
http://www.zerustproducts.com/electr...vapor-capsules
PowerWash is offline   Reply With Quote
Old 01-02-2012, 06:21 PM   #15
Ironlight's Avatar
Actually it's the reverse of that. The hammer is cold and as the trunk heats up in the morning, moisture from the warming air in the trunk/toolbox condenses on the hammer.
Ironlight is offline   Reply With Quote
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 01:34 PM
Rip Claw Hammer or Curved Claw Hammer? Basketball1234 Tools 6 12-11-2011 08:06 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 09:08 PM
Sledge hammer with fiberglass handle... How indestructible are they? xusword Safety 3 04-14-2011 10:13 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
