Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 09-09-2008, 04:49 PM   #1
Question
rotozip or get all separate
i am in a dilemma whether to spend less money and get a rotozip RZ20 (http://www.amazon.com/Rotozip-RZ20-4...0993010&sr=8-2) or spend more and get a dedicated jig saw and a dedicated cutout tool.
as a rule in life, i do not believe that one thing can do it all. the more something tries to do, the worse it performs at each.
i need it for moderate jig saw operations and cutout jobs like installing a new power outlet in a baseboard without taking it out.
Old 09-09-2008, 05:19 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
I think you are correct
One is better for some than the other
It depends
Sometimes either will work
Sometimes one is much superior
Sometimes I use both
I'd suggest a simpler, less expensive Roto
(trust me, you'll add the add-ons you think you might use later)
And a good Jig
slickshift is offline   Reply With Quote
Old 09-11-2008, 09:12 AM   #3
Moderator
Termite's Avatar
Generally I get very little use out of my jigsaw in remodeling. Cutting out sinks is just about it.
I use my RotoZip all the time, and it will do many things a jigsaw will.
Get both!
If you get the RotoZip, definately get a variable speed model.
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 07:13 PM
How do I wire two separate SETS of 3-way switches together? mflagler Electrical 11 08-30-2008 09:47 PM
Looking for a Roto Zip MillerClemsonHD Tools 10 12-31-2007 10:09 AM
concrete crack repair summertime General Discussion 2 10-08-2007 03:59 PM
Scraping hardened concrete from a mixer amakarevic Building & Construction 9 06-27-2007 06:07 AM
