Rotozip: Dissapointed - Tools - DIY Chatroom Home Improvement Forum
Old 04-30-2009, 09:18 AM   #1
DIY til I die!
Angry
Rotozip: dissapointed
Has anyone else had problems with Rotozips? I've been through 3 of them in the last few weeks. I bought the one with the right angle attachment so you can run small cutting blades on it. The first 2 died while cutting aluminum siding. Both times I returned it and got another. I eventually got the job done with them. Now, I go to use it to cut 1/4" deep grooved in pavers, so I can break them relatively straight. I got about 4 of the bricks done and the thing just died. I was not forcing the tool, simply letting it glide and make the cut. It comes with a masonry bit, so theres no excuse for it not to work. Looks like I will return it again.
Zel1 is offline   Reply With Quote
Old 04-30-2009, 09:48 AM   #2
the Musigician
DangerMouse's Avatar
never used one before, but.... where are they making them now? hmmmmmmm
sounds pretty crappy to me.....
DM
Old 04-30-2009, 01:39 PM   #3
Its a rotozip, not an angle grinder.
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 04-30-2009, 02:02 PM   #4
Oldguy
Rehabber's Avatar
About the only thing I ever found the Rotozip did well was make cutouts in drywall
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 04-30-2009, 10:14 PM   #5
DIY til I die!
thanks.
It is sold with blades specifically for cutting masonry, metal, wood, etc. If they sell such blades, I would assume it would work for those materials.
Old 05-01-2009, 12:40 PM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Agreed, The rotozip is for light duty stuff
Get a cheapo angle grinder:
http://www.harborfreight.com/cpi/cta...emnumber=91223
To make straight cuts with any brand 4 or 4-1/2" grinder here is a neat attachment that is surprisingly well built:
http://www.harborfreight.com/cpi/cta...emnumber=45921
Disclaimer
& Stay Safe
.....Bob Lavery
RotoZip vs. Dremel 400 amakarevic Tools 6 03-05-2011 05:37 AM
rotozip or get all separate amakarevic Tools 2 09-11-2008 09:12 AM
Looking for a Roto Zip MillerClemsonHD Tools 10 12-31-2007 10:09 AM
Scraping hardened concrete from a mixer amakarevic Building & Construction 9 06-27-2007 06:07 AM
