-   Tools (http://www.diychatroom.com/f29/)
-   -   Rotary Hammer Drill vs Hammer Drill (http://www.diychatroom.com/f29/rotary-hammer-drill-vs-hammer-drill-74540/)
jrepp44 06-24-2010 10:57 AM
I need to drill 3/16" holes in concrete for Tapcon screws. I have been researching drills and find that a Hammer Drill is about 1/3 the price of a Rotary Hammer Drill. Is a Hammer Drill capable of drilling these holes?
Thanks, Jim
Jack Olsen 06-24-2010 11:58 AM
If you're near a Harbor Freight and you have $29, then this is all you need:
http://www.harborfreight.com/media/c...image_5738.jpg
Or you can spend $49 on the 1" model, which is beefier. I have the bigger one, and it will go through pretty much anything. I used it for the anchor redheads attaching my wrought iron fence to my retaining wall. Quick and easy.
Or you can spend a lot more. But the HF drills are a great choice for this kind of maybe-twice-a-year job.
canadaclub 06-24-2010 01:04 PM
What are you drilling into? 3/16" is not a big hole.
jomama45 06-24-2010 06:48 PM
I personally dispise hammer drills like that & would always opt for a roto-hammer. BUT, I understand that most folks have little use for a roto most of the time. The cheaper hammer drills will get you by OK as long as you buy decent drill bits. Don't plan on using a drill like that & the "free" bit supplied with the Tapcons, and setting any kind of speed record. IMO, I'd suggest saving money on the drill and buying an SDS style bit in the size(s) you need. They will chuck right into a 1/2" or bigger chuck & last far longer, as well as drill faster, than the cheap, throw-away bits.
acerunner 06-25-2010 02:15 PM
both tools are capable. question is how many do you have to do, and how fast. Rotary hammer is definitely better.
The hammer drill is really more like a vibrating hammer. The internal plates have ridges that basically bounce the bit to create the "hammering" action.
With rotary hammers, there are pistons that provide the hammering action with much greater force.
Mr Chips 06-28-2010 08:39 AM
Bigger question is what are you drilling into? If you are drilling into something soft, like brick, block, or motar joint, a rotary bit is a better choice as it will give you a better quality hole. If you are going into a concrete floor or ceiling, a hammer will be a necesity
tapcons are only as good as the hole you drill. make sure you use a bit specifically designed for concrete screws, they are slightly smaller diameter than ANSI standard bits of the same diameter, and your blue screws will not strip out as easily
PaliBob 06-29-2010 06:07 AM
1 Attachment(s)
Originally Posted by jrepp44 (Post 460790)
...... Is a Hammer Drill capable of drilling these holes?
Yes, I used a Hammer Drill to drill a series of 3/4" holes in concrete for lead
anchors to hold 1/2" lag bolts.
