#16 | |
rotary hammer drill or standard hammerQuote:
#17 |
Totally screwed together
Here ya go:
Bosch SDS drill style at $199 It's got all the features you will ever need in this type of tool. |
#18 |
Tool Geek
The choice of a safe type of drill to use on a ladder depends a lot on you. Some of the larger SDS drills are quite heavy and require constant two handed operation. On the other hand a rotary hammer will do the work without you really having to lean on it.
For your application I would probably use a relatively compact Hammer Drill with a 'D' handle for more control, similar to the previously recommended Bosch Bulldog http://www.toolking.com/bosch-11224v...-reconditioned "Spade" accessories are not used for drilling, but only for digging using the "Hammer only" mode.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. & Stay Safe .....Bob Lavery |
#19 | |
#20 |
Tool Geek
SDS-Plus Spade Chisels are available, as are SDS-Plus wood chisels. I have both types.
For digging however the Digging Spades are only available in the larger shank SDS-Max sizes. These are in the 4-1/2" range. http://www.amazon.com/Bosch-Steel-Clay-Spade-HS1922/dp/B0009H5PBS/ref=sr_1_1?ie=UTF8&s=hi&qid=1273222362&sr=1-1 .
#21 |
it didn't occur to me that there are other uses for a 3rd mode (hammer only) such as pulling up tile. I may consider upgrading to the bulldog if the hammer only mode is useful. Is it a lot faster or easier to break up ceramic tile than a cold chisel? Are there other uses?
#22 | |
#23 |
Learning by Doing
DH is looking at rotary hammer drills tonight for me.
If I could only remember to THINK about what I was doing before I did it. |
#24 |
You don't need a rotary hammer to drill into brick. Pick up an impact driver, it's compact, safe to use on a ladder, and perfectly suited to drill into brick. Rotary hammers are primarily used to drill into hard concrete.
#25 | |
I do agree that you don't need a rotary hammer to drill into brick. I've drilled plenty into my brick with a corded hammer drill. Just need good bits & swap them when dulled. That said 5/8" to me is getting on the large side & if I had lots to do I would be looking to borrow or buy a SMALL rotary hammer (with a chisel only function for future uses). Rotary hammers are fun. Just did 1 1/2" holes last week through up to 13" of concrete with one of these beasts : http://www.amazon.com/Bosch-11245EVS.../dp/B00004SUPS At 25 lbs I was very glad the holes were in the floor |
| Display Modes | |
| rotary hammer drill | ctkeebler | Tools | 8 | 04-10-2010 10:42 PM |
| Hammer drill spits sparks | Termite | Tools | 2 | 03-16-2010 03:29 PM |
| Broken caliper bolt | chrissyb | Automotive Repairs | 12 | 12-28-2009 04:18 PM |
| Rookie needs advice - How to remove old thinset from concrete floor? | rookie floor layer | Flooring | 9 | 10-04-2009 01:01 PM |
| Best cordless hammer drill for occasional use | jaym3 | Tools | 6 | 11-11-2007 08:26 PM |
