Rotary Hammer Drill Information - Tools - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 03:16 PM   #1
I just bought, but have not yet received, a Bosch 11236VS-Plus Rotary Hammer Drill.
Can someone explain if there is a difference in SDS and SDS-Plus?
What type bits do I need to purchase?
Giles is offline   Reply With Quote
Old 02-06-2011, 08:13 AM   #2
SXS/SXS Plus
The short answer is, SDS and SDS-Plus are interchangeable, no difference.
The SDS-Max is a different shank style that will only use an SDS-Max bit. So, if in doubt, if your SDS drill does not indicate SDS-MAX on it, then it uses the SDS/Plus bits.
DFW_Handyman is offline   Reply With Quote
Old 02-06-2011, 01:03 PM   #3
Concrete & Masonry
Rewards Points: 620
Correct, you have an SDS+ in the Bulldog, and you can use std. SDS if they even make them anymore.
SDS Max is completely different system with an 18mm shank vs. the 10mm shank of the SDS+.
The SDS+ bits are readily available and you shouldn't have a problem finding a large variety of bits & chisels.
jomama45 is offline   Reply With Quote
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 01:34 PM
Rotary Hammer Drill vs Hammer Drill jrepp44 Tools 6 06-29-2010 06:07 AM
rotary hammer drill ctkeebler Tools 8 04-10-2010 09:42 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
