Rotary Hammer Drill - Tools - DIY Chatroom Home Improvement Forum
Old 04-09-2012, 01:32 PM   #1
Rotary hammer drill
Im in the market for a rotary hammer drill to install some warehouse racking into concrete. My boss will spring for anything i ask for so whats my best bet as far as make/ model?
KJKerns3 is offline   Reply With Quote
Old 04-09-2012, 01:51 PM   #2
Rewards Points: 12,912
If this is for a one time use then you may be better off renting one.
A good one is very expencive.
Trying to use one to small will take far longer to do the job.
Old 04-09-2012, 02:02 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I like Bosch, as far as which model it depends on what size holes and whether or not the holes will be in the walls and or the floor.
These models come in two size bit capacity, SDS Plus and SDS Max. The SDS Plus drills are more popular and come in more models. The SDS Max are mostly for larger holes but because they are heavier they may be more tiring to use.
Also consider dust collection as they can generate a cloud or dust.
http://www.boschtools.com/Products/T...spx?catid=1068
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-09-2012, 02:04 PM   #4
I'll only be using it to install uprights into concrete for warehouse racking. smaller holes, generally. nothing too heavy as far as the storage on the racking.
Old 04-09-2012, 02:20 PM   #5
cortell's Avatar
Rewards Points: 504
Question is how long you'll be using it and how often you'll need it again. One or two days and no expected future use? Rent.
I like the Makita HR4041C. It's on my wish list.
cortell is offline   Reply With Quote
Old 04-09-2012, 02:26 PM   #6
Well its just the one project right now, but it will take me at least a week. I also plan on racking more in the semi - near future (Sometime this year, hopefully) so I wouldnt mind always having it. My boss will buy anything I ask for so I try not to be stingy.
Old 04-09-2012, 02:37 PM   #7
cortell's Avatar
Rewards Points: 504
Sorry. I overlooked the "my boss will buy anything I ask for". In that case, I'd buy Dewalt, if for no other reason it would match all my other power tools ;-) I've looked into their rotary hammers...and ouch. I can't get myself to throw down $1,000 when the Makita works so well for half the price. My addiction to yellow has its limits.
Old 04-09-2012, 04:30 PM   #8
Tool Geek
PaliBob's Avatar
The size of the drill you select depends on the size holes you need to drill.
For 1/2" concrete screws you need to drill 7/16 holes
http://www.confast.com/articles/12-x...concrete-screw
If you use Galvanized 1/2" Hex Head Screws
http://www.homedepot.com/buy/tools-h...ew-126926.html
Then you need 3/4" holes to accommodate the Lag Shield Anchors:
http://www.confast.com/products/tech...ld-anchor.aspx
So if you use the 1/2" concrete screws you will have less drilling and not need the Lag Shield Anchors.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-09-2012, 04:36 PM   #9
For mounting pallet rack I believe the typical fastener is a 1/2x4 sleeve anchor or 1/2x4 wedge anchor. I'd use the wedge anchors and I'd personally buy a Bosch rotary hammer. I have one at work....it drills up to 1" fairly easily, hammers concrete easily.....and has been dropped off a ladder a few times as well with no hiccups!
Doorman54 is offline   Reply With Quote
Old 04-09-2012, 07:57 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,012
bob is right. bosch is a leader when it comes to hammer drills, rotary drills and rotary hammers. ive used their bulldog drills and rotary hammers. all work wonders. most rental shops carry the bosch models as they have the best track record next to Hilti
makita's are nice as well, at work we have two hitachi rotary hammers which work wonders. Hilti is another big one, their usually the best in this class but they cost a pretty penny
as for dewalt. ive used several of their small hammer drills. 1 broke the first time the tool was used right out of the package. the chucks broke on 2 . and all were underpowered compared to other makes in the same amperage
woodworkbykirk is offline   Reply With Quote
Old 04-09-2012, 11:24 PM   #11
In a little over my head
Rewards Points: 706
I own a few yellow tools and have no complaints. But the best hammer drill I've used was a Bosch.
ratherbefishing is offline   Reply With Quote
Old 04-10-2012, 06:10 AM   #12
Tool Geek
PaliBob's Avatar
Originally Posted by Doorman54 View Post
....... I'd use the wedge anchors .......
Wedge Anchors http://www.strongtie.com/products/an...all/index.html
are great for more or less permanent applications but since they are not removable they have to be cut off with a grinder and a new one installed if the rack is moved.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-10-2012, 08:16 AM   #13
I've seen what forklifts do to pallet racks.....wedge anchors are probably the best when it comes to their shear resistance.
Old 04-10-2012, 09:30 AM   #14
Rewards Points: 24
Wedge type anchors are recommended by at least some of the pallet rack manufacturers, and seem to be the most common hardware used, but, assuming that you are buying new racking, it would be best to consult the manufacturer regarding type, size, and depth. As mentioned, they cannot be pulled back out, so are often cut off when the racking is moved, but, depending on what is under the floor, and how thick the concrete is, you may want to consider drilling through the concrete, in which case abandoned anchors can be driven down flush with the floor.
The Following User Says Thank You to DexterII For This Useful Post:
PaliBob (04-10-2012)
Old 04-11-2012, 05:24 PM   #15
Concrete & Masonry
Rewards Points: 470
That's good advice, and should be considered everytime you install a wedge anchor for anything.............
jomama45 is offline   Reply With Quote
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 02:34 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 10:08 PM
Rotary Hammer Drill vs Hammer Drill jrepp44 Tools 6 06-29-2010 07:07 AM
rotary hammer drill ctkeebler Tools 8 04-10-2010 10:42 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
