Rockwell Sonicrafter - Tools - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 01:21 PM   #1
I got a Sonicrafter for Christmas, it comes with an adapter so it could use blades from other manufacturers. It only came with a couple blades and their uses aren't very descriptive, I see so many blades for sale.
What is the best blade to use for cutting thru plaster? My main use for this tool is to cut electrical box openings in sheetrock and plaster/lath. I'd like to stock up on the correct blade for cutting this material. I was hoping people with experience with this tool who already did the trial and error can give me some advice, thanks!
General is offline   Reply With Quote
Old 12-26-2010, 01:49 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Here's some info that might be helpful
http://www.electriciantalk.com/f14/m...crafter-18833/
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 12-26-2010, 03:48 PM   #3
It seems like that thread starter is on the same path as me. In that thread, they weren't very specific about the exact type of blade that they prefer, that is mainly what I am looking for. Instead of buying assortments of blades and having extras that I most likely will not use, I'd rather just stock up on the exact blade that I will be using most of the time.
I do like the one idea from that thread of making your own notches in older blades.
Old 12-27-2010, 07:59 AM   #4
I would use the basic wood-cutting blade to cut through plater and lathe.
oberkc is offline   Reply With Quote
Old 12-27-2010, 08:06 AM   #5
DIY staff
Rewards Points: 7,174
For old plaster and lath--I Start out with the carbide grit half moon shaped cutter to get down to the wood lath---then cut the wood lath with a small straight wood bit---
Having a diamond grout blade and the carbide blade in the box really comes in handy with the old plaster.
Have fun,Mike
Old 12-27-2010, 04:17 PM   #6
I might have to pickup one of those diamond blades. That carbide grit half moon shape blade you mentioned got really bad reviews, people have said that they only got 10 inches in grout before the grit was gone. It was funny because I opened up my brand new set and some of the grit came off that blade just from rubbing in the plastic box
Old 03-12-2011, 11:53 PM   #7
for drywall, i use the metal cutting blade. for grout lines, i use a roto zip or drimal
mveach is offline   Reply With Quote
Old 03-15-2011, 05:43 PM   #8
Johnboy555's Avatar
I have a Fein Multimaster and I simply love it. But I got it long before they lost their patent and everybody started to make one. There are jobs that it does that no other tool can do. I was in the middle of a job of removing panels from a cedar garage door to install glass panels when i noticed that the blade wasn't working as well as I would have liked (it was 3 years old) so I went to HD to see what they had. The Fein blades are very expensive but they will last for years if taken care of... Anyway I saw the Dremmel Sonicrafter for about $100 and grabbed it to see how it worked out. I cut one panel out, boxed it back up and returned it. Compared to my Fein it was not worth $50! It vibrated too much and cut very slow. Haven't tried the Rockwell version yet, but ... Anyway... I use the half moon wood blade for drywall and the grit blade for plaster. Greatest tool for cutting holes in drywall and plaster.
Johnboy555 is offline   Reply With Quote
Old 03-15-2011, 05:52 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The concept of the tool is excellent and I love mine but the blades from Rockwell leave an awful lot to be desired. I have them all and they are all a major disappointment when you consider what the things cost. But of course, that's where their real money comes from. They could double the cost of the tool and improve the quality of the blades and the whole system would get better hype I think.
When I know I am going to use the multi-tool on a job I include the cost of the blades in the quote, It's the only way these days.
XXX
Multimaster is this (or the Sonicrafter) worth the $$ rossl56 Tools 67 02-16-2011 07:38 PM
Rockwell Sonicrafter grout blade source? over60pirate Tiling, ceramics, marble 9 10-25-2010 09:17 PM
Thoughts on a Dremel Muli-max? JCAHILL4 Tools 32 04-23-2010 02:38 PM
