Rip Claw Hammer Or Curved Claw Hammer? - Tools - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 04:35 PM   #1
Rip Claw Hammer or Curved Claw Hammer?
I currently have a 16 oz. hammer and I am looking to get a bigger hammer.
Which type of hammer is better, Rip Claw or Curved Claw?
Basketball1234 is offline   Reply With Quote
Old 11-06-2011, 06:36 PM   #2
DIY staff
Rewards Points: 7,174
Depends a lot on what you are hammering on.
A framing hammer has a 16" long handle to save your back while nailing floor sections on the ground.
The ripping 'claw' is handy for lifting and prying and rather poor at removing nails.
I like a claw hammer for trim and a rip for framing and demo (the rip makes a decent hatchet when you need one.)
An awful lot of new guys loose front teeth to the rip hammer while they are learning--not sure how that happens,but it does.
Old 11-06-2011, 07:29 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 382
I was going to say just that, a straight claw will knock your brains out and a hook claw will tear your pockets and buttons off. But the hook claw doesn't hurt as bad.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
woodworkbykirk (12-11-2011)
Old 11-07-2011, 05:58 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I know a lot of veteran framers who have two 1/2" scars, side by side just above their nose from the straight claw bouncing back and leaving their mark.
That said....That's my go-to hammer.
As far as pulling nails...my straight claw with out-pull a curved claw every day....you just have to know the 'trick'
tcleve4911 is offline   Reply With Quote
Old 11-09-2011, 03:00 PM   #5
In a little over my head
Rewards Points: 706
I'm not a pro by any means. My first good hammer was an Estwing 16oz curved claw trim hammer. My second was an Estwing 22oz straight claw waffle face framer. Between the two, I feel well equipped. I'd like a smooth face framer for deck building, but haven't bought one. Like tcleve said, the straight claw pulls nails just fine, once you know the trick. But lately, I reach for my Dead-On Exhumer to pull nails. I really like that tool. But that's another thread.
ratherbefishing is offline   Reply With Quote
Old 11-16-2011, 07:16 PM   #6
ok Thanks!
The Following User Says Thank You to Basketball1234 For This Useful Post:
oh'mike (11-16-2011)
Old 12-11-2011, 08:06 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
for framing i use a 14 oz wood handle stiletto with a 18" handle i can swing the hammer backwards to drive the claws into a peice of wood to pick it up instead of bending over and split wood if needed if demoing something
for finish work and general carpentry i use a japanese nailing hammer from lee valley, it has an elongated head which looks like a duck and a cats paw style claw which can pull gun nails both from framers and trim guns. with such a short claw it can pull nails even easier than a regular claw hammer
woodworkbykirk is online now   Reply With Quote
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 01:34 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 09:08 PM
Sledge hammer with fiberglass handle... How indestructible are they? xusword Safety 3 04-14-2011 10:13 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
