-   Tools (http://www.diychatroom.com/f29/)
-   -   Riding mower loses power. (http://www.diychatroom.com/f29/riding-mower-loses-power-73466/)
SDM1972 06-12-2010 12:23 AM
I have an older snapper 61" zeroturn mower. After I cut grass with it for ten to twenty minutes it starts popping or backfires and will die unless I disengage the cutting blades. I've changed fuel filter,air filter, and rebuilt the carburator. The charging system doesn't keep battery charged so I have to jump start it every time.Is the problem due to lack of electrical power? Any help would be much appreicated... thanks.....SDM1972:wink:
Yoyizit 06-12-2010 11:01 AM
If you don't fix the alternator/regulator/charging problem the current drawn by the ignition coil will run down the battery and eventually stop the mower.
But for a 20 Amp-Hour battery a half hour seems pretty quick to run down a battery with just the ignition on. A quick jump start, though, will not fully recharge a battery.
